Nov 10, 2021 at 1:40 AM Post #6,301 of 9,265
I just want to confirm, to correctly change region all I have to do is open the CFW settings file and change the region then reboot the player??
Yes. Open settings file in cfw folder, make sure the region code is correct, save and reboot your device.
Nov 13, 2021 at 4:37 AM Post #6,305 of 9,265
hello, When I put in the CFW folder the volume on High the sound is less loud than on the normal gain. Is that normal? thank you
If you have selected the lower gain option in the settings file then yes
Nov 13, 2021 at 5:18 AM Post #6,307 of 9,265
no I chose option 1. but between normal or high gain I don't hear any difference
In the settings file you can chose lower gain, normal gain and higher gain (higher gain only on some models). And then on the player you can chose normal gain and high gain. These 2 sets of settings work independently of each other where the ones in the settings file sets the base line for the ones in the gui.
Nov 13, 2021 at 10:49 AM Post #6,309 of 9,265
it's on a 1z. yes I choose a slightly higher gain in the CFW folder. Between the slightly higher gain and the normal gain in the CFW folder I hear no difference
It’s not a huge difference no
Nov 13, 2021 at 2:06 PM Post #6,310 of 9,265
Anybody still have the original wm1z project Z firmware? Thanks
Nov 13, 2021 at 2:07 PM Post #6,311 of 9,265
Hey, "Warm" in the Walkman One firmware is basically Project Z.
Nov 13, 2021 at 2:10 PM Post #6,312 of 9,265
Yeah i just don't want all 4 different sound style option in walkman one
Nov 13, 2021 at 2:11 PM Post #6,313 of 9,265
Yeah, but once you set the one you want, there is no difference than with a standalone firmware.
Nov 13, 2021 at 2:14 PM Post #6,314 of 9,265
Ok thank you. I will try the walman one.
