Redcarmoose
Sony WM1Z Digital Audio Player:
Sony WM1A Digital Audio Player:
very odd. it very clearly affects something around bass areas, and no, not a placebo when the same bass track can go from lean to ear-hurting bassNot implemented yet.
This is a fake balance slider which does absolutely nothing for reasons mentioned in documentation. Could it be some sort of confabulation?
- super Gain adjustment (Highly recommended)Can someone list the 'features' made possible by Wampy that aren't included in Walkman One? Other than the cool tape effect?![]()
Thanks. Did I read correctly that VPT can be used alongside Direct Source, or is that not possible?- super Gain adjustment (Highly recommended)
- VPT, a whole new dsp effect (Studio Highly recommended)
- 3 EQ options instead of 1 (10 bands, 6 bands, bass/treble/mids) + completely disabling EQ (apparently does something to the sound)
- On the fly firmware adjustments (restart needed, but no PC)
- Low latency DAC mode
Can't think of any more right now, if someone notices there are more please add
Please consult the project documentation. All buttons, sliders and checkbocks have been documented. You can also ask ChatGPT/DeepSeek to pull the documentation from the web and write a summary for you.Can someone list the 'features' made possible by Wampy that aren't included in Walkman One? Other than the cool tape effect?![]()
It is placebo, here is the code (or lack of it).very odd. it very clearly affects something around bass areas, and no, not a placebo when the same bass track can go from lean to ear-hurting bass
Please use terms from documentation instead of making terms up. There is no "super gain", just volume tables. VPT is an effect available on stock firmware for NW-A30/40/50, it was stripped from WM1A/Z and ZX300. You can "completely disable EQ" from standard UI with same effect. "On the fly firmware adjustments" - what do you mean by that, Walkman One config editor?- super Gain adjustment (Highly recommended)
it being placebo is very odd.Please consult the project documentation. All buttons, sliders and checkbocks have been documented. You can also ask ChatGPT/DeepSeek to pull the documentation from the web and write a summary for you.
I am insisting on you reading the docs first so we can speak the same language, making communication much easier for everyone.
Can clearAudio+ also be imported to wm1a/z?
ClearAudio+ is available only on NW-A50; other models are unaware of this option.
ClearAudio+ is not recognized by some filters on WM1Z, so I disabled it.
thanksStraight from the docs:
