Sony Walkman custom firmware (non-Android)
Aug 24, 2021 at 12:29 AM Post #5,311 of 8,232
I could not say exactly because I never used the remote in BT Receiver mode, but only with the files stored on the DAP. As I indicated, the reinstallation of the stock firmware did not bring any improvement for this problem of interference between the Remote and the BT reception in LDAC codec. So I reinstalled Dawn V2 because I am very satisfied with your latest version. And as I was writing to newword666, I also cannot rule out that my Sony XZ2 phone is causing this problem. No difficulty using the Remote with Dawn V2 while listening to music stored locally.
Yes, I too face a similar issue. When I stream LDAC from my wm1a to my Bluetooth receiver, it is very choppy and unplayable as well. With remote as well. Was ok with the previous firmwares. probably the same bug that is causing issues with Bluetooth receiver mode as well.
Aug 24, 2021 at 6:25 AM Post #5,313 of 8,232
@MrWalkman thank you sir :)
could you let me know which among dawn and midnight is supposed to have extended treble?
Dawn is brighter sounding overall with more treble presence. Midnight is slightly darker and warmer. Detail retrieval is still good with both.
Aug 24, 2021 at 10:42 AM Post #5,314 of 8,232
Hi Mr. Walkman. I have an interesting question for you. I’m using Chameleon 3.02 and really like the ability to switch models on the fly.
After installing Chameleon on my 1A, I installed the extended tuning for Project Z. I then used the device to switch to a model 1Z and installed the extended tuning for Midnight. Will the switched model 1A and 1Z each retain their own extended tunings, or does the Walkman only retain a single (last installed) extended tuning?
Thanks.
Aug 24, 2021 at 10:45 AM Post #5,315 of 8,232
When installing the tuning, you should see the update bar going to the end, which can't happen on the old Chameleon firmware.
Aug 24, 2021 at 11:16 AM Post #5,316 of 8,232
The NP=1 option no longer works in the released version
Aug 24, 2021 at 11:25 AM Post #5,317 of 8,232
Aug 24, 2021 at 11:35 AM Post #5,318 of 8,232
What does NP do?
It’s a special setting for Nayparm modded hw that displays that fact in the Unit info and in the Guide to good sound
Aug 24, 2021 at 11:37 AM Post #5,319 of 8,232
Ah, maybe it was experimental.
Aug 24, 2021 at 11:37 AM Post #5,320 of 8,232
Aug 24, 2021 at 3:40 PM Post #5,321 of 8,232
I have food poisoning after eating a burger yesterday, so I didn't feel right all day, and now I even have a fever 😅
The little update should come by the end of the week.
Aug 24, 2021 at 3:43 PM Post #5,322 of 8,232
I'm sorry to hear that...Hope you get well soon!
Aug 24, 2021 at 3:47 PM Post #5,323 of 8,232
I could just have “liked”, but a “Get well soon” greetin is better! Positive wishes from me, anyway!
Aug 25, 2021 at 2:58 AM Post #5,324 of 8,232
This is my setting J region, Midnight, Project Z, Plus V2, Alternate DAC Initialization, High Gain.
So much depth, very very deep bass, wide soundstage, reality off chart; I maybe wrong but it seems even deeper than earlier Project Z2 Test phase. Using 1Z Romi Mod & PW 1960 cable. Ear tips make a really huge difference. I’m using Azla Sena tips,the different Sedna tips I think it’s just different comfort level but sound performance pretty close throughout the different Sedna tips, they are really good although expensive, seems to preserve if not enhance sound quality a bit. Used Spinfit Cp 145 etc it has great stage stability but sucks up too much bass. So yeah, Sedna tips are the one for me. Also I used UM 3DT, it’s really great iem, I think most underrated, best bargain iem of the year, definitely mismatch price vs quality, mad scales like I never seen before and put all my other much more expensive iems to shame. I was on Odin tour, and I like UM 3DT so much more. Definitely needs to check it out
Aug 25, 2021 at 1:40 PM Post #5,325 of 8,232
I'm better now, thanks :)
