What is different when you change your region to J region?You are absolutely right on all accounts. You need to be in 3.02 to go to the aftermarket firmware. And yes, 1.00 is the warmest. You maybe should get to know your player before the new aftermarket firmware. Enjoy! Don’t forget to try a region change, it is a super big deal.
Sony never says that they change the sound. Lol
Sony Walkman custom firmware (non-Android)
- Thread starter MrWalkman
nc8000
Try it, you can always change back. I swap between J and E. J is probably overall more even and safe while E is more exiting but also more unforgiving towards poorer recordings. And yes each new stock fw made changes to the sound. By all means do the full burn in and get used to the stock fw and then play with the custom fwWhat is different when you change your region to J region?
aceedburn
J is always known to be the smoothest all round region for sonic quality and with the best timbre. All the custom firmwares are also tuned with the J region as well. Many have used other regions like E, CA, etc with different results that suits different gears. Best to try it out yourself. If you want be safe, stick with your built in region and only if you want to explore further try changing your region.What is different when you change your region to J region?
gerelmx1986
I still prefer WM1A, tewted ibasso DX300, i wasnt impressed by the sound quality of dx300, too warm and laid back with treble rolled off, if tou say wm1z is too warm... this one is king of it
Hmmmm, switched from stock Region (E) to J earlier tonight, running Midnight (Classic) CFW.....and I actually think I prefer J. This kinda surprises me based on how I've seen J described; figured E would be the region for me.
Not sure if we'll be getting any more CFW updates from MrWalkman (his absence in the forum is very noticeable; he was so helpful in ways beyond his excellent CFW work), but even if that's so, he's done so much to make the WM1x players so dang viable, especially for someone like me who isn't interested in streaming and doesn't want to buy another Android DAP anytime soon. I hope he is well.
Redcarmoose
I found J to be great also but moved to Midnight Plus after a few days. I’m really surprised how well Midnight Plus goes with my collection of IEMs.Hmmmm, switched from stock Region (E) to J earlier tonight, running Midnight (Classic) CFW.....and I actually think I prefer J. This kinda surprises me based on how I've seen J described; figured E would be the region for me.
It will be amazing too if your player matures with burn-in. So depending on your burn-in status, the party is not over yet!
Yeah, not even to 90 hours total (4.4mm out; literally only 2 hours on 3.5mm out) on my WM1A...I know, I know, it is recommended to use stock for a while, but I was missing album art for at least 1/3 of my music and it was bugging the **** out of me. Moving to CFW simply to fix that was worth it, LOLI found J to be great also but moved to Midnight Plus after a few days. I’m really surprised how well Midnight Plus goes with my collection of IEMs.
I need to also test battery life differences between Classic & Plus modes; I recall reading upthread that it isn't a significant difference, but I'm not so sure; need more use to test it out for sure though.
Redcarmoose
No, it sounds like you know what 3.5mm is. There may be a point with a few IEMs where the laidback performance of 3.5mm makes them better, but there are only few. If you like the sound of 4.4mm stick with it. No reason to use 3.5mm any more. I understand that you don’t know what burned in really sound like as 200 hours is typically burn in. But you already have a good idea what that is, there is no harm finding better performance in Midnight/4.4mm.Yeah, not even to 90 hours total (4.4mm out; literally only 2 hours on 3.5mm out) on my WM1A...I know, I know, it is recommended to use stock for a while, but I was missing album art for at least 1/3 of my music and it was bugging the **** out of me. Moving to CFW simply to fix that was worth it, LOL
You will eventually try the stock (if you want) after everything is fully burned in. It will continue to improve over time. I have 1600 hours on my 1A and 1580 hours on my 1Z, and they continue to actually improve. The lion’s share of the improvement was under 400 hours.
nc8000
The plus mode consumes 20-25% more batteryI need to also test battery life differences between Classic & Plus modes; I recall reading upthread that it isn't a significant difference, but I'm not so sure; need more use to test it out for sure though.
Redcarmoose
Wow, I didn’t know that!The plus mode consumes 20-25% more battery
aceedburn
Yeah about 20% more for me but it's well worth the trade off. I listen a couple of hours a day and charge the Walkman once a week when it's still on its last bar. No issues for me.The plus mode consumes 20-25% more battery
nc8000
No problem for me either. I listen 3-5 hours each evening but with the Nayparm upgraded battery I still only have to charge once a weekYeah about 20% more for me but it's well worth the trade off. I listen a couple of hours a day and charge the Walkman once a week when it's still on its last bar. No issues for me.
Hello, does the DMP-A30 series mod work on the A35, or is there no mod for the A35 specifically?
Yes, it works.Hello, does the DMP-A30 series mod work on the A35, or is there no mod for the A35 specifically?
