Apr 12, 2021 at 9:37 AM Post #4,456 of 9,222
Actually my understanding is that you must do the correct revert first to get the hw region/model set correct. If not the stock fw installation will fail.
Indeed. That why I said ideally the stock revert that came with the custom firmware package should be run first either way. But I have tried going straight to stock from some of that earlier firmwares and it installed correctly. Maybe pre midnight/Dawn perhaps.
Apr 12, 2021 at 9:58 AM Post #4,457 of 9,222
You should always use the included Stock Revert file with @MrWalkman firmware as there are other features such as the low battery display on start-up that need to be removed to revert to stock Sony firmware.
Q-6
Apr 12, 2021 at 10:45 AM Post #4,459 of 9,222
Are older versions of the custom firmwares hosted somewhere? I'm expecting delivery of my new WM1A by the end of this week, so haven't been playing in this pool before now. I will follow the consensus advice to stick with stock initially, but am planning ahead.
Apr 12, 2021 at 10:59 AM Post #4,460 of 9,222
Still loving my 1A with MrWalkman Midnight Plus! Have “J” region.
Apr 12, 2021 at 2:19 PM Post #4,461 of 9,222
I ran StockRevert_DMP-WM1_FE.exe without any issue. The wm1a restarted.
However, I got “Connect target device to a computer with a USB cable” popup when I ran StockRevert Ext. Tuning. What is the problem?
Apr 12, 2021 at 2:25 PM Post #4,462 of 9,222
There are 2 stock reverts that have to be run in the correct order and they have to be the ones that came together with whatever fw and tuning is installed on the player
Apr 12, 2021 at 2:48 PM Post #4,463 of 9,222
According the the instruction for Dawn and Midnight (I have old FE but I think it is the same) I ran the StockRevert for FE first which worked, and the StockRevert Ext Tuning which is in the same Zip file, and I get this issue for the later one.
Apr 12, 2021 at 3:03 PM Post #4,464 of 9,222
Apr 12, 2021 at 3:33 PM Post #4,466 of 9,222
Is there a TLDR for someone who can’t possibly make heads or tails out of this 300 page thread? I just got my Walkman so I have a lot to catch up on!
And this is the small thread, the original WM1 locked thread has about 3.000 pages
Apr 12, 2021 at 3:41 PM Post #4,468 of 9,222
Apr 12, 2021 at 5:29 PM Post #4,469 of 9,222
If not concerned about hours run the factory reset from the player as that will clear the problem. For CFW you must explicitly follow the instruction's as prescribed by the Dev to avoid such issue.
Q-6
Apr 12, 2021 at 10:35 PM Post #4,470 of 9,222
Still using / highly enjoying the Midnight Plus w/ J region. Running the new Dunu EST 112, the level of detail retrieval is really something to be heard... The EST 112 is quite a special IEM btw... recommend it highly. The level of sound quality is well beyond the retail price.
