f198
- Aug 30, 2013
There is somebody who can try if ZX1 is working with PHA-1 (as DAC and Amp) ? Thanks.
Tera & NW-ZX1 Comparison
My impressions comparing the two with the following setup
- FitEar MH335DW
- Tera: Wav
- ZX1: FLAC
Tera
- bass is lean
- treble extends smoothly but not sparkly
- more mid focused than the ZX1
- feels more neutral
- feels more organic
ZX1
- deeper bass -> sub-bass extension
- (I could be wrong about this but) sounds a teeny weeny tad more U-shaped coming from the Tera
- treble is sparkly
- more "hi-fi"ish and somewhat more clinical
- feels very systematically "produced"
Summary
ZX1 definitely grabs my attention more easily as it's so clean cut, precise, and (as mentioned) clinical. Whereas the Tera feels more "fluid". I'll use the ZX1 when I'm on the move to 'n fro work, walking around whilst shopping, or at the local Starbucks whilst escaping from paternal duties. But I'll use the Tera when I'm in the gym, or going for a run outside.
I missed that, you said the bass is extended and freq response feels U shaped? Sean would you characterized the ZX1 response as not being flat then?
This is where I wish I could try the ZX1 at a store but can't. I asked the question to PriceJapan but they never answered me back, I understand I can always sell it back however it seems a lot of trouble to try the ZX1.
When I wrote that I was thinking hard if I should have wrote it. That's why I thought I'd qualify myself by saying "coming from the Tera". I think it's perception with the bass extension and more sparkly highs that it feels a little U-shaped when both are side-by-side. Or the Tera has a strong mids emphasis and the ZX1 is more neutral?
I have to admit when I first listen to the ZX1 on it's own I didn't feel that way. It's only when I have the two side-by-side.
Couple of things I appreciate your honesty, secondly maybe the ZX1 by itself would be ok and not having the TP experience I might find the ZX1 just fine and neutral which is good but I do like some good bass once in a while so sounds like I can get that too. I might be more one sided with my music, I am heavy on trance, EDM music with lush pads and wide range synthesizers, I also like Dubstep and those put a lot of pressure on both ends of the scale which I am afraid of missing. I know I can't ask you to guage the player with that kind of music because most likely it won't be in your liking. The best I can ask is can it take such frequency response swing?
Personally for me, if I listened to trance, EDM, etc. (which I don't but I do know what it is, or I'd like to think so) I think without a doubt I'd prefer to listen to that off the ZX1 than off the Tera. The ZX1 extension on both ends is just going to make the tracks a little more exciting to my ears.
However no matter how much a player has its tendencies, it's my personal belief that the headphones will dictate the most prominent signature. If a headphone is U-shaped, (without EQ) I don't think the player, DAC, amp, cables, etc. will be able to make it flip to an delta shape. It's my belief that those components can influence to certain tendencies but not completely change the signature.
Note though, my comparisons between the ZX1 & the Tera has been with my MH335DW - that's all I have with me at the moment. I'm sure some would argue it's not an apples to apples comparison because of impedance mismatch (and they would be right too in pointing that out).
Tera Player should he tried out with Korta Koss modded because thats originally was concepted by Charles.Tried myself with many IEMs and headphones but nothings come so close to the one mentioned above...And after the SQ seen the video how is all hand made by a single guy..ohh boy is very impressive. Time to buy a 128gb sdxc![]()
Hi Sean
Please try it one song with your WM ZX 1 and your Tera with the same file music format WAV
This would be different sq from your WM ZX 1
Thank you
See...I can't really live with just a dedicated headphone per DAP. Not to mention I never really enjoyed the Korta Koss Pro & something about the comfort with it for me. I think it's admirable for what Charles has done though.
Hi Rudi, I can tell ya that I'm not a believer of the WAV vs FLAC vs ALAC vs small capacity SD Card vs large capacity SD Card vs Duracell battery vs Energiser battery. I have tried those combo before in other players in the past numerous times and sometimes I think I hear a difference but it's not replicated consistently and across a wide enough range of scenario to convince me. I'll admit that I don't have dogs ears and in fact for most of you, you'll probably able to listen a one-time comparison and draw a conclusion but I know myself that I have to listen over and over again, on different days, at different times, then average my findings before I can draw a conclusion that applies to me only too.
I'm in Essex England, I wondered if anyone in UK has asked their local Sony dealer what the latest is on an official release here? Even whispers if not an official answer?
