Hinomotocho
https://e-earphone.blog/?p=1323273&...V_qcHMctEpumg_a6-d007h22P73I0QocL8gXGhq9T3AYc
Another offering from Sony
I have yet to see anyone here talking about the rumored successor to the ZX300.
I presume that the new NW-ZX500 won't be android based and probably have new features such as bluetooth 5.0 and newest wifi ax?
??? Bluetooth is implemented in hardware. The chipset capability is baked into the chip. It would need new hardware/chipset to change from 4.x to 5.xI really hope Sony bring an update to the zx-300 that introduces Bluetooth 5.0 too. I really want low-energy Bluetooth so it’ll improve the battery life for when I use it in my car.
Yes, I can see why things like that would give the impression that features can be done by software.I kind of assumed it was a software update... like the AptX update on many Bluetooth firmware on some devices I’ve got. Darn it.
Often game consoles do a lot of the work in software as they have lots of cpu power to spare so you tend to see them add HDMI and other chipset features via software updates but dedicated hardware like bluray players/TV/etc and battery powered stuff like DAPs tend to not have much cpu power (just enough to do the job) so use dedicated chips to offload the work more efficiently. However that then limits the ability to add newer features but often they are in the business of selling you a new device each year too.Yes, I can see why things like that would give the impression that features can be done by software.
What is more likely is that the designers built extra capability that they were aware of, into the chip design, even though the protocol/the design had not been finalized yet, so it could be changed before the final release, so they took a calculated risk that it would probably not change much. And there are probably other functionality that is built into the hardware first, and not available with the firmware at release, as it would take too much time to do everything. Then they can subsequently rework the firmware to incorporate the latent functionality that was built into the chipset. I believe the WM1x added MQA, APE, BT DAC, in this way.
But BT5 would be a redesign of the BT implementation, with the new functionality built into the chipset, so this cannot be implemented by a firmware upgrade to a BT4.x chipset, to make it a 5.x chipset.
Thinking about the above, I realize that a VM (Virtual Machine) could be used. This is software doing both the hardware and software functions, a bit like a MAC running Windows in a Virtual, or emulation mode. In this scenario, then everything can be done in software. But this is costly, to make a general purpose and powerful machine, with the extra power and design to do this. Dedicated hardware is simpler, faster, more efficient, and cheaper, I believe.
Hello Everybody!
Zx-300 dap player work on ps4 pro as a usb dac?
Thanks an answer!
Sometimes my case (Miter) will interfere with charging/data.Have come across a slight issue with my ZX300, and charging.
When I plug in the power cable, the ZX300 starts up, but quite often it does not start to show charging. I have to remove the power cable and re-attach it, to get the ZX300 to show charging.
Not sure if it's since the last firmware update.
The problem is I plug it in to charge, then come to it expecting it to be charged. Only to find it low on power still. … I am getting into the habit of having to plug it in twice to get it to charge. Pain though. Should not be doing it either.
