superuser1
Seems something is up with your music files. Do those very files play on another device properly?
yes they plays well... there is no problem in my android phone ( works in usb player pro with no problem ) .. sometimes when zx300 can't play some files, it restarts ... I made firmware update.. mine 300A model and bought from china. maybe I have to change its regional settings to europe but not an experience on these things.. so I have an marvelous player on my hand and it could only plays 20 songs.. (my music archieve is about 3 tb of flac and dsd... )
I think " 2 Queludes " may not enough for me..
I am from Turkey and even auth. Seller does not know any thing about zx300 yet..
I was hoping to find something useful here but Infortunately nothing will help me I think.. bad luck..
I am using an 64gb sandisk msdcard.. tried three differebt cards ..even in the main memory same problem accurs... by the way a return two times to factory settings and format the sdcards by zx300 itself...Are you using a micro sd card? If so, maybe it's formatted wrong? I'm reaching for straws here. I mean only 20 files are playing and I don't think sonys are really picky on file types and encoding. And I don't recall any of the other 300A owners having trouble playing files.
In my opinion , its about some stupid things about language settings.. maybe if I could able use the "sonynwdesttool" for changing my regional settings C to E... maybe becouse of something different..
Whatever..it seems Nothing possible to do right now..
An Excuse for everybody here but I am really sad about this situation..
Thanks for the attention...
I think I was the first one to ask about the music folder. Simply because mine didn’t work because it never occurred to me it needed to be in the music folder. Sorry for trying to help.Yea.. we all put our music files to music folder.. ok?...
our music files are in the music folder..
İs it clear..?
But it does not play... can not delete or play!!!
Stop saying that " are you sure music folder bla bla..
İf you know something different please say that..
İf you had experience about errors " no song available" or can not playing flacs or dsds..
I am channal mapping my flacs with dbpoweramp.. some files could be fixed.. but for most of them,it does not works ...
I am so disappointed .. ı wish ı did not buy that zx300..
If you check the troubleshooting on any gadget manual they always try to eliminate the obvious first eg problem: gadget not working - solution: is the gadget plugged in? etc.I think I was the first one to ask about the music folder. Simply because mine didn’t work because it never occurred to me it needed to be in the music folder. Sorry for trying to help.
anyway i can get a dignis case delivered to uk? any links, tried via amazon japan and they wont ship
Can't you order it direct? http://shop2.dignis.cafe24.com/product/centum2-zx-300-leather-case/180/?cate_no=85&display_group=1anyway i can get a dignis case delivered to uk? any links, tried via amazon japan and they wont ship
any other case options and websites i may have missed
