AudioBear
- Mar 3, 2007
that's a really good question to which I don't know the answer. Somebody?
There is a lot of opinion in high end audio and listener's opinion's are the worst of it from an engineering or science perspective. That said, the hobby is all about what it sounds like to us. If you found something that sounds better to you than the Benchmark, buy it and love it. I don't own a Benchmark anything either.
But I would counter that the article was written by an electronic design engineer and was vetted by a company that sells equipment primarily to professional applications like recording studios. I would think twice about blowing them off so quickly. Even if they made bad gear, which they don't, that is not a rebuttal to the engineering argument made in the white paper. What exactly can you find wrong with the content of the paper? Oh, and while we're at it what is the proof --beyond hearsay and audiophile opinion -- that balanced circuits have a better soundstage?
Does the balanced out and SE output at the same time with 2 separate headphone connected?
Thanks. Darn. Beginning to wonder if A&K Kann with two SE and two Balanced along with streaming and Apt-x HD isn't a better option for another US$ 200. Any opinions? What other alternatives can match the ZX300? I don't see any.
The Samsung Note 8 smartphone can send music to two BT devices at the same time.Somebody correct me if I'm wrong, but my gut tells me that using a splitter will decrease audio quality. It'd be a shame to use that on a ZX300 if you ask me
Bluetooth is one-to-one protocol (for safety reasons I think, but not sure). Wireless technology that can stream to mulitple devices at the same time is by radio signals, like the Sennheiser RS series.
But that's not very portable, so
your best bet for a wireless two-person solution would be to buy a portable bluetooth speaker, but if you're travelling by plane that's not an option ofcourse.
An impressive feat. Let's hope more devices will follow suitThe Samsung Note 8 smartphone can send music to two BT devices at the same time.
I would help, but I'm not sure what you mean exactly. And btw, the leather is not fake, it's real leather. But it's not vegetably tanned but treated for daily usage.Need some help, for those who has the original flip case from Sony, can you help confirm something for me, in the photo you can see the vinyl or fake leather at the bottom part of the case, does your case have the fake leather covering the full part or is the thin rim near the top is uncovered. Apart from that the case is good quality, and highly recommended over others like the dignis or the ML brand.
Thanks
thanks for the reply, you see the wm port side, that area is covered with a fake leather like vinyl, there is a section of that area not covered, that thin area just above the wmport in the photo.I would help, but I'm not sure what you mean exactly
Ah, I see. Yes, it's the same with mine. That strip was probably too small to wrap it in leather, so you just have bare polyurethane. I like the case a lot, I don't have that irky feeling like with most cases that I want to take it off constantly to showcase the device. Classy case, thick but very protectivethanks for the reply, you see the wm port side, that area is covered with a fake leather like vinyl, there is a section of that area not covered, that thin area just above the wmport in the photo.
