ok thanks that did the trick for me.Remove the stock app running in the back ground. Open up gone mad and try the buttons, it is more tricky. Onkyo hf player app works better with the buttons.
SONY NW-ZX2
- Thread starter leylandi
RPB65
- Oct 11, 2015
How do you stop the stock app running in the background?
proedros
Also "device idle" is eating 77% of my battery. What should I turn off to save my battery
turn wifi-off
enable airplane mode
i leave my ZX2 on all night , like this, when i am sleeping , and next morning i have lost like 1% of the battery
- Oct 14, 2013
Press the "multi Windows" button on the bottom where the back and home button is. Swipe the window of the stock player aside, and voila
Rob49
How do you get the sound adjustment app / icon back on the player ? Went to sound adjustment in "all" apps, clicked it, but the icon has not been put back on the device.
There's an option to clear data, have I got to do that in order to get it back ?
AUDIOBREEDER
- Nov 12, 2012
why are u messing around with the stock app?
- Oct 14, 2013
When you disable the sound adjustment app, the icon will be gone in all apps listing. When you enable it again, you will see it
Rob49
I have enabled it, but the icon is not showing on the home screen. I've gone into sound, & checked that I can use the different surround sound options, which it appears I can, but why is the icon not back on the home screen ??
gerelmx1986
Just one month to CES 2016, wonder what is sony planning
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Lightning deal coming up in about 20 minutes on amazon uk. £577.99
Yeah same price i bought mine 4 days ago , received it yesterday§..Loving it
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Does the stock music player do gapless incidentally?
nc8000
Yes perfectly, at least with flac, have not tried any other format
audioxxx
- Sep 1, 2013
Go to the apps menu where all the grouped icon's are found, you will see the audio adjust icon, then hold it and create a shortcut back where it's missing..
Rob49
Thanks, i'll try & follow your instruction !
Total: 14 (members: 0, guests: 14)
