I have his fw installed.
Sony NW-A50 Series
homesickmadmax
Me too, and not every album art appears. AND my playlists are unchangeable.I have his fw installed.
nc8000
I can't comment on either as all my art has been coverted to baseline jpg and I've never used playlists
- Nov 28, 2016
user @BenGast provided a python script that will convert your album art to base jpg:
https://www.head-fi.org/threads/sony-nw-a50-series.888101/page-93#post-16261626
You’re a star siruser @BenGast provided a python script that will convert your album art to base jpg:
I am glad if it helps.
Don't hesitate to send me your errors by PM if you get some. I will try to correct the code accordingly.
Hi,
So I just got everything set up on my new Sony NW-A55. MrWalkman firmware, caps of and 512gb SD card that has been formated in the player before I loaded thousands of songs on it. Album art shows up and everything looks great in the Album and/or artist section. But when I go into the playlist function I can see hundreds of albums and songs lying there in no logical order at all. When I go into the sense me section there seems that every song there comes from the same artist and album. Anyone knows what might be wrong here? If I wear to delete every track from the playlist manually it would take me forever. But I did try it though, to delete an album in the playlist section to see if I still could find the album in the right place, and I could. For some reason unknown to me a couple of hundreds of them has just been duplicated in the playslist section also.
Hello,Hi,
Can you connect the WM to your computer and look for files with the extension ‘.M3U8 ‘?
There should be 1 file for each playlist. Deleting the file will then delete the corresponding playlist...
On the other hand, I have no idea about the SenseMe issue.
Best,
BenGast
Is this a battery drain issue?
Fw: dmp fe classic
Volume: 45
Files: flac
earbuds
other setting: vinyl, linear phase
I listened overnight (2am to 8am) and my a55 battery dropped 2 bars
Fw: dmp fe classic
Volume: 45
Files: flac
earbuds
Also, I let my a55 alone for 1 day and it dropped 1 bar
weird, i ll try to reinstall the rom.
nc8000
Or recalibrate the battery by completely discharging until it will no longer turn on and then charge it to 100% (battery care/saver disabled)weird, i ll try to reinstall the rom.
thank you, ll doOr recalibrate the battery by completely discharging until it will no longer turn on and then charge it to 100% (battery care/saver disabled)
