skayme
When I use Bluetooth from a PC to SONY NW-A55 with Sony's bluetooth receiver, Is a55 using the DAC or just when I connect via PC USB cable?
It is the A55 dac as the BT signal is a digital signal just like when you use the usb cableWhen I use Bluetooth from a PC to SONY NW-A55 with Sony's bluetooth receiver, Is a55 using the DAC or just when I connect via PC USB cable?
Thanks for your reply. So the quality of sound using DAC PC USB or Bluetooth receiver is the same?It is the A55 dac as the BT signal is a digital signal just like when you use the usb cable
It uses the DAC. But if the music on your PC is lossless, Bluetooth encoding will compress it. If you use the USB it won’t.When I use Bluetooth from a PC to SONY NW-A55 with Sony's bluetooth receiver, Is a55 using the DAC or just when I connect via PC USB cable?
Depends what codec the BT connection uses and if your music is compressed, lossless or hiress. Whether you can actually hear the difference is another matterThanks for your reply. So the quality of sound using DAC PC USB or Bluetooth receiver is the same?
I just put some additions to above comments. The sound latency in USB DAC function is too high and unsuitable for playing videos (unless you set audio shift on the player) or gaming. It's only good for music. In bluetooth receiver mode, it's less lagging still far from ideal to games.Thanks for your reply. So the quality of sound using DAC PC USB or Bluetooth receiver is the same?
Hello sir,No pre-existing database and cold boot w/ 18K tracks (mostly Redbook FLAC, with a mix of high-res FLAC, as well as AAC and MP3): 11:32
Of course, a handful of albums with progressive JPEG -encoded album art. Cleaning those up now, but c'mon Sony - what's wrong with progressive JPEGs?
Still, cool that it all works.
By the way, I formatted the microSD card with the Walkman, which turned out to be exFat.
Weird, because I have the Mr walkman firmware (a50z) and I just upload every album art possible with a Tag Editor. I'd say 20% of the album art are working. I will have to check which are working and which are not and compare them. Do you know if there is a specific file size to have?If you install Mr Walkmans firmware, the A55 will be able to read interlaced jpeg files in the process.
If you don't want to go down that road (you should!) I am not aware of any software that could automatize the extracting->re-saving in non-interlaced->re-embedding the cover art.
Manually any tag editor should be able to extract the cover art, which you can re-save in most photo editing software (make sure you save them as non-interlaced, heh) and the same tag editor can embed it gain. Tedious work.
If you are using iTunes album art might not actually be embedded in the files but only exist inside the iTunes databaseWeird, because I have the Mr walkman firmware (a50z) and I just upload every album art possible with a Tag Editor. I'd say 20% of the album art are working. I will have to check which are working and which are not and compare them. Do you know if there is a specific file size to have?
I used TagScanner, great software. I will try mp3tag tonight. Maybe the album art are too big?If you are using iTunes album art might not actually be embedded in the files but only exist inside the iTunes database
I’ve had art up to 1.500x1.500 but normally use 300x300. I have all in baseline but all the MrWalkman fw should also handle progressive. I always use mp3tagI used TagScanner, great software. I will try mp3tag tonight. Maybe the album art are too big?
Hello Guys,Weird, because I have the Mr walkman firmware (a50z) and I just upload every album art possible with a Tag Editor. I'd say 20% of the album art are working. I will have to check which are working and which are not and compare them. Do you know if there is a specific file size to have?
import sys
import os
from PIL import Image, ImageFile
import io
import music_tag
ImageFile.MAXBLOCK = 2**20
music_formats = ['.aac','.aiff','.dsf','.flac',
'.m4a','.mp3','.ogg','.opus','.wav','.wv']
for d in [x[0] for x in os.walk('.')]:
____files = os.listdir(d)
____print(d.split('/')[-1])
____for file_name in files:
________if True in [ file_name.endswith(form) for form in music_formats]:
____________print(file_name)
____________f = music_tag.load_file(d+'/'+file_name)
____________title_item = f['title']
____________art = f['artwork']
____________if art is None:
________________print("Artwork missing for: ", d, file_name, title_item )
____________else:
________________art_data = art.first
________________if art_data is None:
____________________print("Artwork missing for: ", d, file_name, title_item )
________________else:
____________________art_data = art_data.data
____________________image = Image.open(io.BytesIO(art_data))
________________try:
____________________image.save(d+'/'+'non_prog.jpg',"JPEG",quality=80, optimize=True, progressive=False)
________________except:
____________________image = image.convert('RGB')
________________with open(d+'/'+'non_prog.jpg', 'rb') as img_in:
____________________f['artwork'] = img_in.read()
________________os.remove(d+'/'+'non_prog.jpg')
____________f.save()
The MrWalkman modded fw are supposed to display progressive jpg album artHello Guys,
I also had a covert art issue: covert arts in iTunes that are saved as progressive JPG are not visible on NW55.
Here is python3 script (based on this project: https://pypi.org/project/music-tag/) that should do the trick.
If you run the code below inside the MUSIC folder of NW55 it will loop over all your music files and:
Enjoy the cover's!
- open the file metadata,
- extract the cover art,
- convert it as non progressive JPG
- put the convert image back in the file metadata.
Best,
BenGast
Python:import sys import os from PIL import Image, ImageFile import io import music_tag ImageFile.MAXBLOCK = 2**20 music_formats = ['.aac','.aiff','.dsf','.flac', '.m4a','.mp3','.ogg','.opus','.wav','.wv'] for d in [x[0] for x in os.walk('.')]: ____files = os.listdir(d) ____print(d.split('/')[-1]) ____for file_name in files: ________if True in [ file_name.endswith(form) for form in music_formats]: ____________print(file_name) ____________f = music_tag.load_file(d+'/'+file_name) ____________title_item = f['title'] ____________art = f['artwork'] ____________if art is None: ________________print("Artwork missing for: ", d, file_name, title_item ) ____________else: ________________art_data = art.first ________________if art_data is None: ____________________print("Artwork missing for: ", d, file_name, title_item ) ________________else: ____________________art_data = art_data.data ____________________image = Image.open(io.BytesIO(art_data)) ________________try: ____________________image.save(d+'/'+'non_prog.jpg',"JPEG",quality=80, optimize=True, progressive=False) ________________except: ____________________image = image.convert('RGB') ____________________image.save(d+'/'+'non_prog.jpg',"JPEG",quality=80, optimize=True, progressive=False) ________________with open(d+'/'+'non_prog.jpg', 'rb') as img_in: ____________________f['artwork'] = img_in.read() ________________os.remove(d+'/'+'non_prog.jpg') ____________f.save()
Warning : This script is modifying all the cover art the music files contained in the folder wher you run it. Please don't blame me if all cover arts are messed up afterwards... I suggest to try to run it first inside a folder containing a sample of test files.
