1. Download tool
https://www.dropbox.com/s/w1j3sj99v679af0/scsitool-nwz-v23.exe?dl=0
2. Connect the player to the computer.
3. Check the letter of your nw a45 in "My Computer" / "This PC". For example: WALKMAN (H: or D: or E: or J: or whatever)
4. Download the file
https://www.rockbox.org/wiki/pub/Main/SonyNWDestTool/open_cmd_here.bat and put it in the same folder as the tool (point 1), and double-click on it
5. Enter the following command, replacing X with the version number of the tool (
v23) and
H: with the letter of your WALKMAN drive in "My Computer" / "This PC". <dest> is the localization code
scsitool-nwz-vX.exe H: dest_tool set <dest> <sps>
so if you double-click the file in step 3, copy and paste this and just replace H with what your PC shows
scsitool-nwz-v23.exe H: dest_tool set E off
you press Enter and after that you go to the settings of your walkman and Reset it
