SONY IER-Z1R
Mar 25, 2022 at 6:13 AM Post #11,701 of 15,437
Having pulled the trigger today on Z1R, time to join this thread... fingers crossed they fit!
The pairing with your M9 likely will be Aural-Nirvana level. Having them driven out of the C9 and the LP6K/SR25MK2, power and slight warmth do wonder with the IER-Z1R, this with many genres.
Mar 25, 2022 at 6:38 AM Post #11,702 of 15,437
Welcome to the Promised Land. If EXT fits you, I don't see any issues with Z1R, but you never know. Just be sure to have a selection of tips available.
Yep!
Mar 25, 2022 at 7:08 AM Post #11,703 of 15,437
Welcome to the club, owning Sony daps and the amp and following the threads how did you resist the Z1R for so long? I have faith they'll fit like a glove.
How much would you have spent on all your tips?
Mar 25, 2022 at 8:08 AM Post #11,704 of 15,437
Fit was always a concern and I had no way to try them - that led me on a path exploring various other IEMs, ultimately now bringing me back to what was the most desirable to me at the start!
Cost of tips, I'd be nervous to total them but I'd take a guess there must be $400-$500 worth! I have a tip FOMO issue, almost anytime I read X tip is the best ever, I'd immediately buy!
Mar 25, 2022 at 8:19 AM Post #11,705 of 15,437
Mar 25, 2022 at 8:26 AM Post #11,706 of 15,437
Mar 25, 2022 at 8:36 AM Post #11,707 of 15,437
Mar 25, 2022 at 9:34 AM Post #11,708 of 15,437
Don't worry, they will probably fit. You'll probably be quiet around here for 30 days after .......................just trying to get up off the floor due to sound shock.
This is pretty much what happened to me :)
They are a very mind expanding set.
Mar 26, 2022 at 3:15 AM Post #11,710 of 15,437
What are some of the best aftermarket silver cables do you guys recommend?
I'm on that side of thinking where "Silver cables are pure snake oil"
Thinking of picking one up to try and putting the claims to bed, at least for me.
Mar 26, 2022 at 3:47 AM Post #11,711 of 15,437
I’m using Dunu Blanche on both my iem’s. Partly because I like the silver sound, but mostly because of the swappable tips
Mar 26, 2022 at 5:30 AM Post #11,713 of 15,437
How's the fit on the connector side? Heard some say the z1r mmcx is a little bit recessed?
Yes it’s recessed so will be hell to remove the cable again but that is the point of the Blanche that I never have to remove it as it has the swappable plugs the other end
Mar 26, 2022 at 8:00 AM Post #11,714 of 15,437
I would recommend the pure silver type-6 litz from Khanyayo Cables (aka @doctorjuggles )
Incredibly well crafted and very high quality cables at a much cheaper price than the big brands. Check out his work on Instagram: https://instagram.com/khanyayo_cables?utm_medium=copy_link
Mar 26, 2022 at 9:14 AM Post #11,715 of 15,437
