OverlordRush
How is the isolation of these? pretty good for train travel?
Pretty good with normal volume, but with DD isolation is still not as good as BA IEMs, but its a lot better than ex1k
And does it sound good?I plug my IEMs into a Hugo TT2 since I listen at home most of the time and it's got the iem output
The only IEMs I currently have are a A12t and a Z5, but they both do sound way better than using my phone. I don't own a DAP and probably won't get one as I really don't need one. I like good iems at home because I have a bad neck and I need to use lightweight headphones or IEMs with my desktop setup. I wouldn't mind getting a DAP, but I probably wouldn't spend that much on one as I listen to most of my music while at the computer.And does it sound good?
9k worth of audio gear on a 10RMB plastic chair...
got to try the Z1R with Z1 today, it somewhat fix the unnatural female vocal issue and the treble also sounded less sharp. too bad Z1 is not really a portable option.
Is that really a E1K.Took some pictures at the local Sony event in China!
Z1 with my E1k
well, I only find the impression said that z1r > u12t > qdc vx
Wonder which no bass music he used ?https://review.u-audio.com.tw/reviewdetail.asp?reviewid=1608
Found a Taiwan review written in Chinese, the writer rate it as the best IEM to date.
