SONY IER-Z1R
Jan 16, 2021 at 2:55 PM Post #9,603 of 13,737
gerelmx1986
Germany
Really? Doesn't the M7 have recessed sockets like the Z1R? haha did you effectively use it as a pair of plastic pliers rather than putting it between the joint?
I used normal to get in between the male and socket, then like a knife the tool gently inside in between the two and it popped easy out
Jan 18, 2021 at 9:21 AM Post #9,605 of 13,737
Ocelitgol
Previously known as stormers
NYC
Jan 20, 2021 at 5:43 AM Post #9,607 of 13,737
425455
This is an exerpt from a (non head-fi so apologies if it is too simplistic) post I made elsewhere which might be of relevance I think to ier-z1r owners ....
In December 2020 I bought a brand new pair of Sony's ier-z1r and yesterday after closer inspection of the left connection - which was detaching from the iem rather too easily I thought - I discovered that the tiny copper sleeve which should have been on the terminus of the cable connector pin was actually in the female receptacle of the body of the iem.
Now, I had noticed this before, but assumed that the left and right pins of the connectors were different diameters by clever design - to prevent the user connecting the left side to the right iem and vice versa.
It was only because I bought some MMCX to 2Pin adapters (which didn't fit the left side), on the recommendation of a fellow head-fier (@Tristy I think), in order to use my 2 pin cables with the ier-z1r that the penny finally dropped.
Final confirmation was this; the Sonys come with not one but two sets of cables and the second pair wouldn't fit on one side either.
So, back to Sony they go!
I'll let you know how I get on!
Jan 20, 2021 at 6:13 PM Post #9,610 of 13,737
LCHF
Sydney
I’ve been using my z1r’s on a LG v50. Would a WM1A be a noticeable improvement in sound quality? If so, is the difference as big as going from lg’s standard dac to quad dac?
Jan 20, 2021 at 10:39 PM Post #9,611 of 13,737
DynamicEars
My LG v40 cant drive Z1R to their great potential, I assume its the same with v50. On my DX160 balance, they sound very much different.
the dynamics are different, transient also very different, on V40 they sounded flatter, Z1R really needs juice to be shine. Let alone bass impact. Bring your Z1R to audio store to try various DAPs, with 4.4 balance connected
Jan 21, 2021 at 5:47 AM Post #9,612 of 13,737
gerelmx1986
Germany
If you're switching cables out on the Z1Rs frequently, are you running the risk of damaging the connectors on the earphones? I know this is an issue with other mmcx iems such as those made by Shure..
That happened to me with the xba-z5, after just 3 or 4 cable swaps, the left side bud failed and didn't connect securely anymore
Jan 21, 2021 at 7:03 AM Post #9,613 of 13,737
Redcarmoose
Still my favorite IEM, still totally special.
Jan 21, 2021 at 9:16 AM Post #9,614 of 13,737
musicinmymind
Scary, I will not swap anymore. it was between tianwaitian by CEMA vs ALO siliver litz.
Soundstage is expansive with ALO, it made me feel like HD800 and mids are so sweet with tianwaitian. After multiple swap settled with tianwaitian, but it would great if I an get both in a different cable.
Both these cables are much better then stock cable for me, especially imaging is on different level with tianwaitian.
Jan 21, 2021 at 9:23 AM Post #9,615 of 13,737
JerryHead
SoCal
Interesting. Anyone else try the Tianwaitian cable and can give their impressions? Looks like it’s only available through Ali Express, so returns can’t be easy.
