SONY IER-Z1R
Apr 4, 2024 at 4:06 AM Post #15,196 of 15,290
Those AZLA look interesting but I always suspected it would tame a lot the air frequencies because of how they're made. There's too much foam surface after the stem ends.
I just found this Foamax comparison graph, even though its for N5005 but you can expect a somewhat similar effect on Z1R (pretty much aligned to what I hear - tame the treble a bit and clean up the low end)
Source: https://www.youtube.com/watch?v=UJaPDpD2baA
Yeah, if the same happens on z1r as n5005 the foammax change the response quite a lot.
Apr 5, 2024 at 12:16 PM Post #15,197 of 15,290
I've got a problem. I haven't used the stock cables in forever, and now the ear hooks started disintegrating whilst kept in the box and are now all sticky or something...? Is there something I can do about this? :worried:
Apr 5, 2024 at 1:08 PM Post #15,198 of 15,290
From what I can gather it's not that uncommon and a replacement cable is the only real solution.
Apr 5, 2024 at 2:09 PM Post #15,200 of 15,290
Common problem. Several have simply cut the soft rubber ear guide off the cable
Apr 5, 2024 at 3:16 PM Post #15,202 of 15,290
Hmm...well, cutting it off doesn't like too bad of an idea, after all, it is a double sleeve. And it's definitely a nice way to save a bit of money on a cable i rarely use!
For cutting it off, what, do i just grab a random kitchen knife or something small and sharp and just go at it?
Apr 5, 2024 at 3:53 PM Post #15,204 of 15,290
For a while, until the electrical tape also starts going bio-degradable :ksc75smile:
Okay, if you expose it to high temperatures, yes, it might, but you have similar tapes with a textile outer part; use something like that instead.
I use electrical tape, and it's fine for years at room temperature.
But if you are not safe to do that, better don't...I have been using it for at least 30 years for anything when I need it.
Anyway...if that tape starts to peal...you can tape another one and another one..for as long as you wish...but I have experience with it.
Easy for me to say :wink:
In that case...Aliexpress is your best bet :)
Good luck!
Cheers.
Apr 5, 2024 at 5:03 PM Post #15,206 of 15,290
Mine just detached from alone at the base of the male mmcx stem, so i ripped it off. Unto clear the stickiness, I just claimed them with isopropyl alcohol.
Apr 5, 2024 at 5:44 PM Post #15,207 of 15,290
1. Whipe it with alcohol swabs until no longer sticky.
2. Dry out with clean cloth.
3. Always store in a case with silica gel.
Apr 5, 2024 at 11:35 PM Post #15,209 of 15,290
It happened to my IER-M7 cable and the solution I found was to clean it thoroughly with isopropyl alcohol and to use a silica gel packet inside the case I use to store them.
Following those steps they're not sticky anymore!
Apr 6, 2024 at 11:38 AM Post #15,210 of 15,290
Thank you for the Alchool solution! I will try it out soon™
