Low stock in Australia, but there are dealers that still have stock for now.
![IMG_8466.jpeg IMG_8466.jpeg](https://cdn.head-fi.org/a/12339857.jpeg)
whats your serial?My Z1R was produced just last year, so I don’t think it’s discontinued.
I finally got around to polishing my Z1Rs after more than two years of accumulating microscratches and dirt. Was such a quick and easy process - well worth the simple effort to get your Z1Rs looking like new.
Have you tried any other eartips other than stock ones? How do they compare to foamax?I have found new favorite tips for Z1R. It's the new Azla Foamax tips. Super comfortable, seal well, has earwax protection, better separation and a tad 'cleaner' bass and treble than stock silicone tips. Only downside I can think of is it tends to round off the edginess on notes that it makes the Z1R lost its aggressiveness somewhat - it sounds better to me but I could imagine some wouldn't like this characteristics.
It's really simple. Just get the brand in the picture, follow the instructions, and voila! As new Z1ROh damn, polishing the z1r! How did I not think of that? Is there some specfic guide/things I should use to polish my precious earphones?
Damn, it's that simple...? Now I'm even a bit sad I've had my z1r in poor condition for more than a year. Shame on me!It's really simple. Just get the brand in the picture, follow the instructions, and voila! As new Z1R![]()
I have tried quite a few tips, including Final E, Sony Ep11, entire Sedna series (except xelastic 2), spinfit W1 + CP?? (I don't rmb the number), JVC, Radius Deep mount series, also the stock tips coming from my other sets in my sig and a few others that I can't recall the nameHave you tried any other eartips other than stock ones? How do they compare to foamax?
That's a large amount of eartips! I tried xelastic 1 a while ago, to me they didn't seem very impressive, but it's been a while since I used them.I have tried quite a few tips, including Final E, Sony Ep11, entire Sedna series (except xelastic 2), spinfit W1 + CP?? (I don't rmb the number), JVC, Radius Deep mount series, also the stock tips coming from my other sets in my sig and a few others that I can't recall the name
Sound quality wise I'd rate Sedna Origin > Stock silicone > Sedna Foamax > else
Fit wise Foamax > Stock Silicone > Stock hybrid > else
One small trick if you want to try foamax is before putting the iems in your ears try squeezing hard on the tips to deform it first, then insert the iems, then after 10-15sec the foam will regain its form and fill up your ear canals. Perfectly sealed
I ordered a set of Xelastec II yesterday, should arrive tomorrow, let's see how it fares
I just found this Foamax comparison graph, even though its for N5005 but you can expect a somewhat similar effect on Z1R (pretty much aligned to what I hear - tame the treble a bit and clean up the low end)That's a large amount of eartips! I tried xelastic 1 a while ago, to me they didn't seem very impressive, but it's been a while since I used them.
I only remember that my ears were winning in the grip competition and even xelastic was slowly pushed out of my ears.![]()
Source: https://www.youtube.com/watch?v=UJaPDpD2baA
