I would advise going with option two... It's what I did only after choosing option one.... There were several times when unplugging the 3.5mm jack from the outputs on the back of the A16 that the device froze, locked up, and or shut down. It was very frustratingOne final quick question for the group. I put this measurement off for one more day, b/c there was a fair amount of noise around the house today, and I know tomorrow will be much more quiet.
I still have one question though. I seems to me I can do AudioHobbits PRIR capture method one of two ways.
1. I can just asign a speaker label for each of the outputs--like "12" for Rb and "3" for sub and just select those two and plug up the output A16 output so assigned for each of the six PRIRs which would of course necessitate replugging after each PRIR.
2. I can just re-assign outputs 1 and 2 with the speakers I wish to capture for each PRIR. which would necessitate changing the labels for outputs 1 and 2 for each of the six PRIRs.
Does it make a difference which I do? Will each method work? I have the A16 on a table in front of me, so it's no problem to replug, and likewise, it's not problem to reassign speakers to the output I want. Will it make any difference? I think, for example, as long as my Listening room has a"Ltb" speaker, it's not really going to matter which A16 output was used to make it as long as the souce speaker has the correct geometric relationship (Ltb in this example) to my head's listening position, and I properly did my "headtracking Asist" Kabuki dance.
Amirite?
Relabeling the PRIR is really no big deal... As far as the speaker setup... All you need to do is use the adjust buttons to change output one and two to the desired speaker.. only takes a few seconds.
Using the @audiohobbit method It's very easy... But I urge you to press the test button at the end of every measurement (prior to saving) to make sure that you don't see any anomalies in your frequency response.. this feature helped me pinpoint a dead tweeter in my center channel.
Also... If you should move the speakers or you're listening position... Please be sure to recalibrate for those speakers in that position.
Some tips that I've learned during the measuring process.
It is helpfulto limit the output volume of the device as to not blow your speakers if connected directly to a power amplifier... The sweep was very, very loud the first time I measured.
Leave enough slack/play in the lines of the microphone while connected to the lanyard... Otherwise, tilting and turning your head during the look angles will pull the microphones from your ears.
The head tracker assist is very useful... but so is making sure that the A16 is within your line of sight... doing this allows you to see the actual angle of your head displayed on the screen.
Like you, I was very concerned about the noise in my house... The air conditioning turning on, the refrigerator, breathing, creeks and groans in my throat, even the sound of my heart beating in my ears... But I was most concerned with the vibration of the walls and doodads in my listening room caused by these sweeps of the LFE... Thankfully... None of these things had any real bearing on the sound reproduced by the A16.
Hope this helps
