sander99
Ah, coaxial is an advantage in this case, now laying them flat sure doesn't create any problems for the perceived horizontal direction (not sure that a small sideways distance between tweeter and midranger could, but now there is no problem for certain).My speakers are KEF R3. Does it matter how I put them flat? As in option A or B?
The center of the tweeter (so the center of the coaxial driver) would define the origin point of the sound, so that should be at the desired angles.
Woofer inside or outside: doesn't really matter for the perceived position. It could be that one sounds better than the other because of other distances from the woofer to ceiling and side walls, and depending on your over all acoustics but there is no way for me to say what's best. Except: one little advantage of having the woofer inside would be that after toeing in the coaxial driver would be the most forward driver, so less chance it's sound is influenced by the top of the bookcases.
Look, if you really wanted to do it all perfect you would have to ask acoustic experts, do measurements, use room treatment, room eq, etc. etc. Otherwise just do what is most practical and hope for the best...
Now with this arrangement you could measure the ltf and rtf, and looking away from the speakers the ltr and rtr. But what are you going to do for ltm, rtm? You could do those one by one by first sitting such that one of the two speakers - the one that you measure - is on your left side (for the looking forward measurement) and then such that one speaker is on your right side (if you use the other speaker for that then you don't have to change connections).
Alternatively you could just sit in front of the speakers on the bookcases and bend forward such that the top of you head points to the line between the speakers, then you could measure those 2 together to keep things simple.
When I did my 9.1.6 measurement with two speakers I did a few channels one by one, and I didn't have any problems. Others had problems with single speaker measurements but I wonder maybe those problems only arised when trying to create PRIRs all containing one speaker?
Is your plan to create one PRIR with all the channels (replugging cables), or a number of 2 channel PRIRs (without replugging cables)? In both cases you can split the step for ltm and rtm in two without changing connections (inbetween measuring ltm and rtm I mean) and while putting them together in one PRIR (either the one big PRIR with all channels, or a 2 channel PRIR for ltm and rtm).
