sander99
For the moment optical only works for user A, that is correct (will be a future firmware update to make it work for both users).Tried head tracking with tho headphones attached to the A16 yesterday.
Optical only seems possible for user A.
Magnetic however also seems not to work correctly. Both user A and B outputs react on movement of HT connected to user A. The HT of user B seems to be ignored completely.
Anyone noticed this too?
fw 1.91.
After powering up and/or connecting the head trackers it takes a few minutes before it starts working (then the led on the headtracker turns green).
If you have activated the "B->A" function, with wich you can sent the user B part output to user A headphone outputs, then the head tracker signal of user A is also controlling the user B part. After switching off this mode, I think (not sure how it is with the current firmware) sometimes the user B stays linked to the user A headtracker. Make sure the "B->A" function is deactivated and do a power off - power on then I expect it should be working (maybe you first have to wait a few minutes again).
[Edit: I mean disable the B->A function in the settings menu,
[Edit2: excuse me, under System:Misc settings]
