Fox1977
Lucky him !! I'm checking my mailbox and spams regularly, but so far nothing... Maybe it will come this afternoon or early next week (i keep my fingers crossed !)
Is anyone using this for games with an atmos feed from their PC via USB? (Or successfully using any atmos content via USB?) I am trying to debate where to put this in my house: my TV room, which I barely use anymore for anything other than occasional TV and movies with my wife (who has zero desire to use this for that purpose) or my computer, which is where I primarily use my headphones.
Well, sure, I guess what I left out was 3 years ago when I paid for this thing I primarily used my headphones in my living room. (I basically have two gaming setups at both my computer and in my TV room.) I just never use it anymore because my kids have taken it over. But if there was some technical issue I missed, e.g. Atmos not working via USB, I can just switch to over there and go back to HDMI. (My computer desk gaming monitor is DP.)I think that you clearly suggested a reasonable choice: where you primarily use your headphones.
If your monitor's DP input accepts HDMI signals (some do), you can buy a cheap HDMI<>DP cable, otherwise an active adapter, otherwise inexpensive converter boxes are available. You can also use one HDMI output just for sound and connect that to the Realiser and leave the output of the Realiser unconnected.[...]My computer desk gaming monitor is DP.
Thanks, I forgot about the possibility of using HDMI out for audio only. (I am using G-Sync via DP and don't want to compromise that.)If your monitor's DP input accepts HDMI signals (some do), you can buy a cheap HDMI<>DP cable, otherwise an active adapter, otherwise inexpensive converter boxes are available. You can also use one HDMI output just for sound and connect that to the Realiser and leave the output of the Realiser unconnected.
But that seems to be a limitation of the A16 USB driver, other USB devices may be able to accept ATMOS streams - but maybe I'm misreading the description for the Dolby access App. For VLC and Kodi, the A16 USB driver seems to disable streaming of even "normal" DTS and Dolby Digital sound tracks. Does anyone want to ask Ploytech (https://www.usb-audio.com/; the makers of the USB audio device in the A16) if that is a general limitation of their driver or specific to the A16?AFAIK over Usb only PCM is possible. Up to 16ch with the correct driver I think.
Atmos bitstream only via HDMI I suppose.
