Kozwoz
- Nov 26, 2014
I own and i’ve tried the SE846 with the iPhone 4s/5s/6, rMBP, fiio e12a, Chord Mojo, AK240, Cypher Labs AlgoRhythm Duet and AudioQuest DragonFly and experimented with various combinations. The Chord Mojo and AK240 are quite phenomenal paired with other headphones I own. I use SXC 24 from ALO Audio which certainly adds a bit of a shimmer. I’ve yet to remove the foam from the blue filter. I’m actually very sensitive to treble. I listen to drum and bass, dubstep and deep house mostly. I hate sibilance and I’m particularly sensitive to snares at 8khz. I find the SE846 very smooth with very low levels of distortion but instruments to my ears lack upper harmonics which the SE846 can inherently not produce whatever equipment I throw at it. It is these upper harmonics that gives everything definition and realism. I realise I’m probably in a minority with my views. Theres truly a lot of wonderful things about the SE846 but the way it conveys those higher frequencies is not one of them in my opinion. I will try removing the foam - thx for the tip. My issue is not with making it more or less ‘bright’. Boosting EQ or using the white filter just accentuates what is already there. It doesn’t add fine detail imo.
