I have the tw2, it is a nice add on, but it is a night and day difference connecting the se846 cable connected to my amp.I get mine with the TW2 later today. I’m not really an audiophile but it should be easy to tell how much the adapter degrades the sound. I’m just going to use the stock red filters since I used to use the blues with my old pair. Didn’t like the other two filters back then.
Shure SE846 Impressions Thread
- Thread starter jelt2359
maegnificant
They do degrade the sound, less so than the FIIO UTWS 5 at least. Personally I prefer the white over the red filters.
Armament
Night and day seems exaggerated. They don’t need that much power. I do understand that they’ll suffer some quality loss from the wireless connection though.I have the tw2, it is a nice add on, but it is a night and day difference connecting the se846 cable connected to my amp.
It has nothing to do with power. But connect it to a decent dap or amp, and you’ll know what I meanNight and day seems exaggerated. They don’t need that much power. I do understand that they’ll suffer some quality loss from the wireless connection though.
Armament
I tried it on a Mjolnir/Yggdrasil stack when I had them out of curiously. No difference between that and my phone.It has nothing to do with power. But connect it to a decent dap or amp, and you’ll know what I mean
Well if you can’t here the difference between crappy bluetooth codecs or a clean akm 4499ex dac/amp or a chord dacs, decent r2r dac I give up. I use the tw2 as well, but not for serious listening. There nice and convenient that’s allI tried it on a Mjolnir/Yggdrasil stack when I had them out of curiously. No difference between that and my phone.
Armament
Lol I didn’t say that. Obviously there’s a difference between Bluetooth and a wired connection. But for the SE846 IEM there was no difference between the two wired connections.Well if you can’t here the difference between crappy bluetooth codecs or a clean akm 4499ex dac/amp or a chord dacs, decent r2r dac I give up. I use the tw2 as well, but not for serious listening. There nice and convenient that’s all
fablestruck
Then check the quality of your audio files?Lol I didn’t say that. Obviously there’s a difference between Bluetooth and a wired connection. But for the SE846 IEM there was no difference between the two wired connections.
fablestruck
Also the output impedance of your source is important
Armament
It’s that hard to believe that there is no difference between the two? I’m not going to convince my self that the difference is “night and day” when there is none. I have always used FLACs or Tidal when listening to my “high” end IEMs. Maybe there’s a difference with higher end/more expensive IEMs but I haven’t heard any as of yet. I can tell a difference when using headphones from lower end vs higher end equipment though.Then check the quality of your audio files?
mattclarke18
You can always verify they are genuine by calling Shure and giving them the serial number which is on the box. They should put it on the IEM itself but then if they did for sure no Gen1 owner could get the red filter. Please let us know if the TW2 degrades the sound as I get mine tomorrow. The BT2 was horrible and it had very limited range before it cut out. The TW2 is suppose to go 10 meters which is what I need as I will be using mine at the pool while floating on my raft later this spring and summer. It is IPX4 water resistant which means it should be able to be splashed with water or rained on and still be ok. I really like the SpinFit CP240 double flange tips on my 846s. They allow just enough bass but also open things up so tracks have more life to them. Prior they were too bassy and didn't hear the treble enough, hard to describe in words.
fablestruck
No it's ok if you don't, maybe your non-DAC source is already decent.It’s that hard to believe that there is no difference between the two? I’m not going to convince my self that the difference is “night and day” when there is none. I have always used FLACs or Tidal when listening to my “high” end IEMs. Maybe there’s a difference with higher end/more expensive IEMs but I haven’t heard any as of yet. I can tell a difference when using headphones from lower end vs higher end equipment though.
But one thing you can try is to listen to a track very familiar to you that includes some musical depth and detail and see if you hear 'more' information with a DAC or not.
Armament
Yeah I'm definitely going to try again with my RME just out of curiosity. I'm getting a WM1A for my Z1R but if the difference is negligible then I would be more than happy to return it.No it's ok if you don't, maybe your non-DAC source is already decent.
Gonna try this today. Will let you know what happens. ThanksHave SE846 gen2 for two weeks now and it's instantly my go to, midrange as clear as I'd hear from speakers, bass outstanding, because there where is a lot of bass, you get a lot of bass, there where is no bass, you get no bass, just as you would expect from monitoring speakers. It came as default with new extended filters preinstalled and to me highs extension lacks nothing, to me these sound like end game, stage is not as wide as on my Westone W80 or Mach80, but I get all the details and balance sounding extremely "right". My go to, even got me thinking about getting a second used pair as a future back up.
Amazing that these originally were released like in 2013...
Armament
Total: 8 (members: 0, guests: 8)
