fablestruck
Spinfit CP800That's right, that was probably the problem!
Please advise the best silicone sleeves for se846? Preferably those that can be bought on bhphotovideo or thomann
Thanks!Spinfit CP800
No worries.Thanks!
Final Audio Black+Black/Red Silicone Type E Eartips kit with Case and Nozzle Adaptor Compatible With 1More, AKG, Audio-Technica, Beats by Dre, Campfire Audio, Empire Ears, Shure, Sony, Westone (Multi) https://a.co/d/hvNqswvThat's right, that was probably the problem!
And what size is needed if the standard from Shure fits Large?Final Audio Black+Black/Red Silicone Type E Eartips kit with Case and Nozzle Adaptor Compatible With 1More, AKG, Audio-Technica, Beats by Dre, Campfire Audio, Empire Ears, Shure, Sony, Westone (Multi) https://a.co/d/hvNqswv
The kit comes with allAnd what size is needed if the standard from Shure fits Large?
There they also have options in the XL or Large set. If buy it is better to have the right size in reserve.The kit comes with all
sizes plus the adaptors.
What can you recommend a quality DAC for the iPhone?I tried tw2 with se846 and I have the apple lightning dongle, my honest opinion I read good stuff about the apple dongle, but I don't agree with that at all, it's okay at best. The TW2 bluetooth sounds better than the apple dongle. I would advice to get a decent USB DAC for the iPhone.
I also checked the se846 with a decent dap and then the cable connection wins from the TW2. I guess getting a good USB DAC for the iPhone, then a cable connections will win from the bluetooth connection I guess. That said, the TW2 is really really good, and I mean really really good!! I was highly impressed with it, together with the se846.
My self now deciding getting the gen1 se846 again or the gen2 with the new red nozzle an nice color schemes, if only I could find some decent review regarding the red nozzle, the gen1 is quite bit cheaper than the gen2. (And will use the TW2 with that as well)
I can't really recommend to much on dac's but heared good stories about Hiby FC3 and FC5 or the Shanling UA5. I am planning to buy the FC3, seems more than enough power for the se846 and runs on ESS 9281Pro chip which is a low power high quality dac. And the FC3 is a really good priced (small) dac and can be ordered together with a lightning cable.
regarding colors, what I like about the gen2 is that de new colors Jade and Graphite is color combined with clear, so best of both worlds.
