- Jun 4, 2014
That REI really is impressive for something so tiny. And no pressure here, but you could stream your smartphone through it...
Penon Audio in my experience, has been trustworthy. They sent my gray-red eartips for the Andromeda without any issue.
I would personally choose the REI, because it’s super-small, gives headphones a bit more power to them (app-measured +5dB increase in volume for my Massdrop X Fostex TH-X00 Ebony), and is compatible with most all devices you can throw at it.
Good luck, and let us know what you decide to purchase!
Most definitely - able to stream through the smartphone is a feature I superbly agree!That REI really is impressive for something so tiny. And no pressure here, but you could stream your smartphone through it...
No worries! If you wrap the REI to your phone, you can technically hold both against your cheek! Your phone can act as the Bluetooth to compatible Bluetooth products.Thanks. I do love that Sony unit but the downfalls you pointed out are what I've been thinking. Talking about good battery life tho the q5 has 8-10 hours and with the rei drawing battery from phone the battery life will probably be about the same , so I guess mute point. Probably now just between the rei and the q5. Sexy slim design that I would probably hold against my cheek or bluetooth and self powered.
Oh that’s right. I forgot to mention this as a reason why I’d go for the REI. I will always say that I personally enjoy the REI’s sound signature even more than the Mojo, from listening memory and experience.
It looks like Penon Audio can ship it to your door in the US (that’s exactly what they did for me), so you should be good to go!This.
Yeah this is definitely what I'm leaning towards. Really wish someone in the US sold it so I don't have to wait forever. Penon audio has a ebay account I think I'll order it from so I can use my coupon.
Woot! That’s a great price for you. Hope you enjoy the beejeezus out of it!Alright pulled the trigger on the rei and got it for 450 shipped Coupon code is PSPRING20, good for 20% off any item until 8pm PT.
There ya goLol yeah I better I'm putting a lot of money into this just so I can listen to Istanbul not Constantinople in hi Def
Here’s the full specifications of the REI:What's the output impedance of the REI?
More info is here:
- Input: MicroUSB
- Output: 3.5 TRS
- Output voltage: 1 Vrms at 32 ohm
- THD: 0.0005%
- S/N ratio: 118 dB
- Bitrate supported: Up to 32bit/384kHz
- Support systems: Mac OS (driver-less USB 2.0–3.0), iPhone 7, iPhone 6/6p, iPhone 5s/5c/5, iPad Pro, iPad Air2, iPad Air, iPad mini series, iPad touch (models with lightning). For Android OTG support, please check with the manufacturer in the product manual. *edit: also compatible with iPhone X when CCK is connected*
- Dimensions: 2.75 x 1.5 0.25 in
- Weight: 0.72 oz (20.0 g)
https://www.massdrop.com/buy/cozoy-rei
So they don't list the output impedance then? That's a critical spec for the SE846.
