Mr-Nice
- May 4, 2016
My advice would be to use the earphones with the cable they come with for a while before deciding to purchase another one. The cable it comes with is also silver (if that makes any difference...) and given that it was designed by Shure, should have low impedance.
I purchased another cable for ergonomics reasons. I don't like a memory wire, it hurts my ears after a while. Sound quality will not get better and may actually get worse if the impedance is higher than the standard Shure cable.
FYI, any company that has in their marketing material...
... should be avoided like the plague for promoting such utter nonsense.
EDIT: to illustrate my point even further, I decided to quickly test a few cables I had laying around here. I'm not one to name and shame, so I'll keep it relatively vague.
Note: these were single line DC resistance measurements, not loop AC resistance. I don't have the equipment for that test. But given that capacitance of these cables is typically so low that their impedance is virtually flat, it's a decent enough indicator.
- Shure original short cable: 0.4 Ohm
- Japanese "4-core" silver cable with balanced trrs 2.5mm plug ($50): 1 Ohm
- Japanese silver-plated OFC ($100): 0.8 Ohm
- Polish made 4-core 7N UPOCC copper + UPOCC silver in semi-Litz ($149): 0.7 Ohm
- HK made 11-core silver plated copper balanced trrs 2.5mm plug ($39): 0.4 Ohm
Couple conclusions:
- I use 4 and 5 because of ergonomics or if I want to go balanced
- Price is not an indicator of performance...
- The Shure is better/equal to all if you can handle the ergonomics
EDIT 2: added one more I forgot about
Greetings
So any solid advise for a great cable, also I never knew that the shure should only use cables that 0.4 ohm
What effect will it have on sound if I use a cable with 1 ohm ?
Also does using the original cable from Shure make volume lower than using other cables?
Cheers
