Shanling M2x - TIDAL || Wi-Fi || Both-way LDAC BT & BT Transmitter || Advanced USB transport || FW 2.7
post-15486841
Post #526 of 587
SpaceMilkA79
Texas
Texas
I managed to sync my playlists to the M2X, however when I try to play them on the device it says file not found, however I can play all the music through the All Songs section. I am using M3U.
post-15487326
Post #527 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
Such error would mean that something in your playlist is not set correctly, might be name of drive (MTouch uses A as drive name) or structure doesn't exactly match to folder structure on your Micro SD card.
Reactions: cel4145
post-15487505
Post #528 of 587
goranilic
How to play my M2x on a car radio, I tried to connect it with USB to all outputs, but nothing > I used USB to C-USB; USB to 3.5mm jline out and USB to 2.5 balanced.
What I am doing wrong here. Settings or folders on the card !?
Could you please help me>
Thank you,
post-15487566
Post #529 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
Thank you,
USB to jack will not work, since M2X doesn't have analog output in USB port. If you want to use analog input on your car radio, use analog output on M2X (3.5mm jack)
In which way does your car radio deals with USB devices? Simple connect some drive and then browse files on it through system of car radio?
post-15490228
Post #530 of 587
goranilic
Not sure that I am following here. My car has only regular USB output. I do not have idea which way car radio deals with USB devices. Actually, I have Apple iPod video and it is connected to car radio by USB and that strange wide jack to iPod.
What do you suggest to do?
Thank you.
post-15490599
Post #531 of 587
SpaceMilkA79
Texas
Texas
Changing drive letter of the micro SD card to A worked. It was originally D. Now it seems I can play all my music so far. However, I noticed that a significant amount of the tracks say "Unknown artist" even though they are all properly tagged. Before, when I synced to a phone, music apps were able to properly display all tags including artist name. What is causing this? Any way to fix?
post-15490748
Post #532 of 587
cherryind
India
India
@Shanling, Today I received M2x i bought. Fantastic piece of engineering. I have a question, what does the High gain do? I know it increases gain but of what? DAC chips gain or Opamps gain or something else? I'd love if you can answer..
Didn't Shanling see my post or they don't just bother to acknowledge or to answer my question? I must say my first experience isn't very good ! :frowning2:
post-15493500
Post #533 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
Thank you.
Does your car stereo supports playback from USB devices(like flash drives)? Ipods are working in special way, just because your car works with ipod doesn't mean it will work with other USB sources.
Does your car stereo have audio input(3.5mm jack connector)?
You can send us some file for check.
Sorry, missed it. Gain is changed in digital domain.
Reactions: cherryind
post-15495809
Post #534 of 587
cherryind
India
India
Thanks for the reply.
Which has the higher distortion? Low gain or high gain?
post-15496399
Post #535 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
post-15510843
Post #536 of 587
Test222
Europe
Europe
@Shanling
Would it be possible to increase the number of tracks in Recently Added (currently 100) or to let us choose folder sorting (by name/by date)?
post-15515015
Post #537 of 587
alexdemaet
Belgium
Belgium
Will the M2X support (ripped) DSD64? I ripped DSD from SACD's. I tried to play them on Shanling M0 and Fiio M9. Unfortunately the devices only played a few DSD64 music files.
post-15515019
Post #538 of 587
alexdemaet
Belgium
Belgium
Will the M2X support (ripped) DSD64? I ripped DSD from SACD's. I tried to play them on Shanling M0 and Fiio M6. Unfortunately the devices only played a few DSD64 music files.
On the Shanling M0 I got the message "not supported file not found"
And on the Fiio M9 I got the message "file not found"
post-15515882
Post #539 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
Well, which form of DSD? Do you have it as separate .dsf file? Or do you have it as ISO file, in which case is it DST by any chance? DST is not supported by our system due to to high demands on processing power.
post-15516144
Post #540 of 587
alexdemaet
Belgium
Belgium
It are dsf file that I ripped from a sacd and dsf files that I recorded from vinyl
