Hi
@Shanling or anyone who can help me with this important question,
I am using the Shanling M2x player with Etymotic ER4XR headphones, and also sometimes the BLON03 and Sennheiser HD600. But usually the Etymotics.
I want to make sure that the volume is set at a safe level, especially as I have tinnitus and I don't want to aggravate it.
I realize that some tracks are louder than others (especially as I'm using the last version of the firmware which does not standarize the volume between tracks).
Usually 85db is considered a safety cutoff, I believe. So I suppose I wouldn't want to get above 75db on any track. But I dont know, you know what I'm saying, I just want to keep the volume in a safe zone.
Any suggestions about what the max volume I should set with the Etymotics ER4XR? Or the others? Or in general? How high do you let the volume creep with your various headphones and the M2x?
I'll be using low gain, never high gain.
Thank you very much for any ideas. I don't have the technical knowledge to figure it out myself based on specs. I do have a dB meter program on my ipad but I have no idea how reliable it is.
THANK YOU!!!!!!!!!!!!!!!!!!
