Shanling M2x - TIDAL || Wi-Fi || Both-way LDAC BT & BT Transmitter || Advanced USB transport || FW 2.7
post-15453388
Post #511 of 587
mamakanx100
Manila
Manila
Hi @Shanling got mine last November of 2019. All of sudden, the volume wheel skips whenever I adjust it for some reason. I updated my firmware, however, its still skipping. Any workaround for this one? Is it a faulty unit?
Reactions: Gjoel
post-15454478
Post #512 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
By "skips", what exactly do you mean? When you move wheel it sometimes goes for 1 more?
post-15460486
Post #514 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
Yep exactly, sometimes it jumps at least 3 or 5 skips, either up or down.
If it's showing such big jumps, it might be hardware issue in wheel mechanism. So either contact your seller for warranty or get replacement wheel mechanism.
post-15475363
Post #515 of 587
darkcamel2018
uk
uk
does this model allow control from a mobile phone, connect via wifi or bluetooth bidirectional control?
post-15476246
Post #516 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
You can stream audio files into M2X over Bluetooth and Wi-Fi, but there is no app for just remote control of the M2X.
post-15476786
Post #517 of 587
darkcamel2018
uk
uk
can anyone answer my newbie questions?
1. wasnt there spposed to be a phone app as it was promised over a year ago and Chinese version was supposed to be beta testing. Fiio have Fiio music, Hiby has Hiby music.
2, Also i just bought this device, and good quality but Blutooth seems a bit average audio quality (bass seems lacking) using aptx setting to a minirig..doesnt seem to be the case if i stream blutooth from my phone, any thoughts to change settings, gain etc to improve it.. seems fine via line out.
3. how do i access DNLA server.. i have turned on wifi, connected to my router, and switched DNLA on. .but where do i access it?
4 Connected my phone to stream blutooth at LDAC quality then output the audio via line out to a speaker, but the volume is set to max and cannot seem to adjust it.. how do i lower the volume as its almost blowing my speaker?
thanks in advance :)
post-15478004
Post #518 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
1) We were forced to change developer of the app, still in works.
2) Other settings have no impact on Bluetooth sound quality. Your phone is also using aptX? Or some other codec?
3) M2X works only as DLNA Rendered, you need to use some app on your phone/computer as controller, to access files.
4) If you want to control volume, turn of the Line Out mode on M2X. You can also control volume on your phone.
post-15478730
Post #519 of 587
SpaceMilkA79
Texas
Texas
1) Does M2X accept external playlists?
1a) If so, what formats? (m3u/m3u8/m3u EXT)
2) Can M2X read special characters in track names such as in "Gymnopédies", "凸】♀♂】←巨人", or "고마워"?
3) Can M2X read lossy AAC files (.m4a file extension)?
post-15481726
Post #520 of 587
Test222
Europe
Europe
1) Idk.
2) It can read some. Not all sadly. But it can read all of these you quoted.
3) Yes it can.
post-15482605
Post #521 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
1) Yes, it supports external playlists, m3u is recommended.
2) Korean works fine, and we are continuously adjsuting MTouch system for other special characters from other languages.
3) Yes, no problem.
post-15484018
Post #522 of 587
SpaceMilkA79
Texas
Texas
I purchased the M2X and when I connect it to my PC with the USB it constantly connects and disconnects. I installed the USB driver and the issue still persists. How do I fix this?
post-15484034
Post #523 of 587
SpaceMilkA79
Texas
Texas
Nevermind, I got it to connect by using a USB 2.0 port, USB 3.0 ports don't work. But now I have a new issue and that is that I cannot get MusicBee to sync with it. There is no folder structure in the micro sd card even though I already updated the firmware. How do I sync?
post-15484228
Post #524 of 587
Shanling
Sponsor: Shanling
Shenzhen, China
Shenzhen, China
MTouch system doesn't have any pre-set folder structure. It reads anything you put on Micro SD card, no matter if it's 10 layers of folders or just all songs in root folder.
If you want to sync any software with the micro SD card, it needs to create its own structure.
post-15484616
Post #525 of 587
cherryind
India
India
@Shanling, Today I received M2x i bought. Fantastic piece of engineering. I have a question, what does the High gain do? I know it increases gain but of what? DAC chips gain or Opamps gain or something else? I'd love if you can answer..
