Welcome @Fornax
1. You might be better sending an email through to Sennheiser for the answer to that question. I have heard that the old models (160, 170, 180) were interchangeable as they all used the same transmission technology but never tried it myself. Going by that the new ones should be as they also use the same transmission technology but the tech support would probably know the answer better.
2. This thread will give you a bit of an idea about the difference between analog and digital connections for these sort of headphones. DAC shouldn't make a difference for the analog connection either as all the processing is done by the transmitter internally but that might be worth emailing about as well.
Thank you, great forum and informative threads.
I also read about cross-pairing between the older RS-160/170/180 series, which is where I got the idea from. There doesn't seem to be info on whether that is possible with the new RS-1X5 series. I guess my questions about cross-pair were rather specific and nit-picky. My local electronic stores do not have the new RS series, so I can't try them out. I will try Sennheiser support. Thanks for suggestion.
Since a DAC-Amp will not be useful for wireless headphones, I should weigh getting DAC-Amp for wired headphones (I just have the HD598) or go wireless for about the same cost or a bit more.
Q: Any opinions on how the RS-175 and RS-185 will sound relative to the plain HD598 playing off a computer analog out? (Mac internal DAC, AAC/ALAC/FLAC, no amp; music: bit of everything - classical, rock, jazz, alternative) Will Schiit M2M2 + HD598 change the comparison much? The computer has S/PDIF out, so that could/would be used on the RS-175/185. I understand the HD598 and RS185 are open headphones, and the RS175 is closed and the bass-boost use is fairly subjective.
