Coldsnap
- Jul 30, 2010
Well, I got both. Going to fully test and pick one. I'm a bit worried about my ears getting hot with the RS 175, otherwise that would have been my choice without testing.
Good idea. That is always the best way to go about it if you have the money and you able to return easily. How big are the internal dimensions of the ear cups btw? Considering getting one of them but worried the ear cups might be too small looking at them.
Inner ear cups are 1.25" wide by 2.25" high in the RS 185. Seemed big enough to fit over my ears and my friends had no complaints.
ok so I bought those RS 170 and I highly do not recommend those headphones. Sound is rly nice according to my CAL, even more bass, but this annoying hiss/hum/buzzing noise in right ear is just terrible... I cant stand this noise when music is not playing or between tracks.
Also its not a fault of my audio source because when you plugg off audio cable from receiver there is a still this annoying noise...
I'm gonna return those tomorrow
Anyone have opinions of the connection quality of RS220* vs RS185?
RS220 uses a connection type different then the 170/180's *and* the 175/185's, correct?
** EDIT: n00b2 and Coldsnap discussion above stated that additional amp "make no difference as all the processing is done by the internal amp in the transmitter" a few posts back, ty for info.
Short version, 2 Questions on the Sennheiser RS-175/185:
Q1: Is it possible to use HDR-185 headset with RS-175 base? Do the 185 features work?
Reason: Purchase RS-175 first, consider upgrade with HDR-185 as accessory 2nd headset.
Q2: DAC/Amp not needed/useful for RS-175/185 with optical input? DAC might be useful if analog input?
Reason: Considering purchasing Schiit stack for wired headphones.
At the price point of RS 175 and 50 +/- do you think that its the best wireless headphones out there for casual movie viewing, or even audio?
I have been looking forward to getting a wireless HP for a while, i own some good wired headphones though such as the HD800 and the LCD-X, I value audio/video hence asking. I do realize the limitations of a wirless system. I heard the RS 175 at AXPONA today, and was immediately blown away.
Last i researched about a wireless headphone and one particular model from Sony was the top favourite of the forum, since senn has released the rs 175 does the equation tilt or does it still remain the same?
