Vitaly2017
i added the ifi idefender 3.0 and found it very helpful.
Hi do you use a regular usb a to b with idefender or is it shield ?
I defender goes into the iMac and the USB cable goes from there to Hugo 2, I sold my HDv 820 for rogue rh-5. When I had HDv 820 I was using 2qute which I also sold.i briefly had the hugo 2 with the 820 and it sounded really good as well.Hi do you use a regular usb a to b with idefender or is it shield ?
I'm hoping someone has some solution for the following problem: I have a Mac and I cannot play DSD files natively on the HDV 820, which it is supposed to be able to do.
I think this is because there are no ASIO drivers provided by Sennheiser for Apple users (they do provide them for Windows users on their website). I installed Windows (through Parallels) on my Mac and got the DSD files (64, 128, 256) to play natively using JRiver. But in the Mac OS, in JRiver, I get the error message that playback of DSD 256 files is not possible. JRiver on Mac _can_ play DSD 64 and DSD 128 files on the HDV 820, but that is only because it is converting them via the DoP protocol--it is not sending the native DSD files to the HDV, which is capable of playing DSD natively, and does do so in Windows.
I have been in touch with Sennheiser in Germany and they have given me two different answers. First, they said that they were aware of the missing DSD drivers for Apple users and were going to rectify it soon (February 2018) and today they told me their engineers, upon investigating the matter, say that the files can indeed play on Apple computers without a problem. I've sent them an e-mail as they requested detailing the issue since I cannot get DSD files to play natively from any program in my Mac OS (Audirvana, JRiver), but thought I would explain the issue here in the hopes that someone has a solution. Or perhaps I just need to wait for Sennheiser to produce the missing drivers? Thanks for any help!
It is my understanding that Mac OS has no native DSD support. You can only play DSD files over DOP. If you want native DSD, you’re going to have to use Windows. Full stop.
I had to deal with this issue while reviewing the Questyle Golden Reference system. My main computer is a MacBook Pro, but I had to use a PC with the Questyle CAS-192D Golden because Macs don’t do Native DSD.
Correct, I was not happy with the Sabre dac and decided instead to use 2qute as my dac. I am connecting the HDv 820 to the 2qute via rca. Assuming we see the gain switch as a clock going 8,10,12,2,4 I have found the 12 o'clock position has by far the best sound but as I said it also distorts on my HD 800S. Thus I have been using the 10 o'clock position.
How was the overall sound with the 2qute as the dac. I read a review of the 820 where they said the dac sounded identical to a chord mojo.
@Sennheiser What is the power output in watts at various resistances (8 ohm, 16 ohm, 100 ohm, 600 ohm) of the HDV 820?
Thanks.
Hehe not that low sq. It still sounds better then mojo.
Hdv820 has also 40 ohm of output impedance
They kept saying 12 watts nominal power output on their website. I am surprised to see it is only 2.5 watts at 50 ohms. Other top end SS amps are much more powerful, 430 HA - 8 watts at 50 ohms, Wells milo - 12 watts - 32 ohms, rag - 10 watts @ 50 ohms. Does impact its ability to drive demanding headphones?
K maybe my graphe is bad then? Cause I found it on the net earlier and just saved for references.
I also tryed audeze XC and X and lcd 2, they all worked fine on hdv820 on single ended not balanced.
The sucker had issues was aeon flow open back, it was always low volume. also single ended.
I guess in balanced theses headphones would perform way better.
