If you own an Android phone and root. Can install Viper4android via Magisk and you use increase volume output via Bluetooth. This always works with my Bluetooth speakers when volume is too low.
What is quality expectation of a BT model like this at this generation? I'm interested in this model, but all the BT sets I tried failed to impress. Are these like as good as 1MORE Triple Driver In-Ear Earphones at last?
I ended up returning my pair. It was just too much work to insert them and get a good seal. None of the included tips were a good match for me and the Comply foam tips felt too mushy and loose. Also, I'm pretty sure there was a channel imbalance with my unit. This is disappointing because I thought they sounded pretty good and I like the design.
My search for true wireless earbuds continues. Maybe the new Pixel Buds are next. I don't need aptX and noise cancelling because I'll be wearing them out in the street so I want to hear my surrounds.
I didn't have any luck with the included tips either. But I used a cheapo silicone set I found on amazon and it's an easy and quick fit every time. These IEM's really shine with a good seal. At first it took me a few seconds to get these in but now it's muscle memory they are in my ears in a second. Easy peasy.
Your review is worthy of reading for any level of experience. It's very professional, and I appreciate the work.
I disagree with a couple of small items on latency factors and the ability to work out while in-ear. however, as with most truthful reviews, it's a personal thing.Thanks for the review, very helpful.
