I am still on my stock silicone M. I tried so many eartips including the AET07 which many here liked it and the Final Audio Type E but still went back to the stock haha. It sounds so good with the stock.
The tube hole needs to be very large to feed your ears properly without impacting the sound quality... till now the only after market tips I have found with a long and large tube are the AZLA SednaEarfitLight ... no other one could replace the Sennheiser for sound quality. The Azla are far easier to put inside the ear canal than Stock Sennheiser for IE900..
Interested in this but my local store only has the short version.
Another reason why I like the stock tips is because it has waxguard and foam insert so I feel safe about not letting anything goes inside my IE900. I find it amusing how sound is still so good with those in the eartips haha. Amazing job Sennheiser!
You can take some wax protection from the foam tips and stick them in the azla tips.
I agree, I really enjoy the sound quality of the Sennheiser standard tips with the IE900, the only real issue is that it's a bit too tricky to seal them perfectly in the ear canal (but it can be done).
We are many in this thread from the beginning to struggle to seal the standard IE900 tips and keep them seal for a long time....so I gave up and I tried to find some other tips.
Otherwise, In my case, the Xelento is more comfortable than the IE 900 (Sennheiser cable is too noisy and hard and makes it a permanent feel around the ears).
But I still prefer IE900 SQ... less than IER-Z1R SQ and a bit more than Xelento...
Xelento is really the most comfortable, the IE900 less .. and IER-Z1R, even less than the IE900, and can't be used lying down with the head on the side.
Agree. I think the issue is because the flaps are very thin. Don’t know if flaps is the right word for it haha. But I think they get folded sometimes while in the ear canal. Got to readjust till they have a good fit. That’s the annoying part. But once it fits, its good to go.
This exactly. I come across this mistake at times in my IEM journeys. If you make a thin silicone tip, it has to be moldable. In this case, when it's pushed out of the shape it wants to be it folds. That's not the reaction you want, it should flex not fold.
I wonder which IEM would complement best with IE900 ?
Thinking about UM MEST MK II or U12T, but haven't tried any of those.
I previously had Andromeda, and don't think they are great combo with IE900.
That’s a good point ! I listen to rock , classical / OST and EDM and IE900 is really good at those . I just feel I want to switch to another IEM to listen the same music with a different sound signature , maybe something a bit warmer, but still technical, with good amount of details and big soundstage
The only way up from IE 900 in that case is perhaps something like a Legend X or EVO, but they're both much more expensive. The VE EXT is probably also a step up and in line with that sonic profile. You can also get a warmer IE 900 (though less technical and resolving) for 1/4 the price in the IE 300.
Thanks! How would you say IE900 do in comparison with Mest MKII ? Does any of those have better bass / soundstage / detail retrieval? Or, as you’ve mentioned, they are on the same level ?
