Aevum
- May 15, 2007
get some skull candys, they look great, sound like a hippos digestive system, but look great,
Originally Posted by Possédé /img/forum/go_quote.gif The highs are a little rolled off, but using treble booster on my iPhone, it has opened the highs up without distorting the music [I usually have my equalizer off]. All I can say is I am really enjoying these earphones, and I'm sure the highs will open up a bit more the more I burn them in. |
Originally Posted by toughnut /img/forum/go_quote.gif According to some users, the bass GONE after 200 hours burn in. U need to max the knob to get bass. Weird iem indeed... |
Originally Posted by Cecala /img/forum/go_quote.gif I don't know about the C700s isolation level, can you give an example here about them. |
Originally Posted by jwbrent /img/forum/go_quote.gif Well, I have about 78 hours on my IE8s... When new, the upper frequencies had a thick, syrupy sound to them and the bass was bloated. After about 10 hours of play, both of these areas improved and have continued to improve since. The sound as they are now are reminiscent of a traditional sounding tube amp; recessed at the top end but with a glorious midrange. There is no hint of fatigue which I like very much. I have the bass at the 3 setting and have not noticed any diminishment of bass quantity, but it has tightened up. The soundstage is as advertised, excellent. Not only in the lateral sense, but also in terms of depth and height. In fact, I've never experienced an earphone reproduce image height before. Fantastic! I'm using Comply T-400 tips since they provide the greatest comfort compared to the supplied tips. I have noticed if you push in the earpieces too much (trying to accomplish the best seal), the squarish plastic housing rubs up against the ridge of your ear causing discomfort after awhile. I would not recommend shallow tips for this reason. More to come... |
Originally Posted by musictang /img/forum/go_quote.gif mine burned around 20 hours, high-mid-low getting harmonies quality sound...just that the punchy bass amount drop to the stand i starting to worry.. i am a basshaed, i got set to highest Bass EQ(Sony player have high bass EQ) to get more boom. i need to check into Comply tip for greater comfort and isolation... |
Originally Posted by Fruits /img/forum/go_quote.gif Im thinking of getting the Comply T-400 tips to go with the IE8, would they be a good choice? or is there any other recommended. Thanks |
