[..] If you found the HD598 bland (which I find is somewhat close to neutral), then you may find the HD6XXs boring. I don't know for sure though.
Your preferences seem to lean on the bright side. Not exactly a region related difference. Depending on your sensitivity to treble, you may like brighter headphones.
Yes, you may be just right.
With
DT 990 Pro it was mostly the booming bass which was my problem, - not so much the high frequencies. And I do like
Sony V6 - but I do not like them with 2g
shuffle or an amp, only straight from
Sansa Clip+. And
Lowthers are bright, and I actually gave up on a subwoofer, - but I amp
Lowthers with SE DHT (
300B), and I like that much better than previous solid state solution.
That being so, I really do like
DT 770 Pro.
Speaking of regional preferences, in Europe there used to be more 2-way stand-mount/bookshelf speakers, while in the USA there was a tendency to have 3-way floorstanding speakers, and I believe that the power of an average quality amp differs several times, too. Some of it has to do with the size of livings, as well as detached houses versus terraced and condos, but that is not the whole story.
Now came to think of it, I probably made a mistake, as
I did not properly listen to classical on HD598.
Alas, that's too late now.
But they did not impress with the few instrumental bits I came across, going through tracks at random, nor with J.Joplin's
Mercedes Benz, or some songs from
Peter, Paul and Mary (well, fine, bit nothing to write home about), and they did not impress with
the Smiths or
Аквариум, not to speak of
Ramones or
Meat Loaf.
So while there is a chance that I have overlooked a great pair of headphones for classical, I do not think it happened.
Another big problem for me remains that
I really could not live with their build quality. It was like "born again"
HD515, just a few years forward and for ~240% of the price.
I can live with plether/ leatherette, but I do not think much of it, and I could not see any substantial improvement apart from the grilles.
HD515 were value headphones, but at the price point of
HD598 I expect more. After all they were more expensive than
770 Pro, and more than twice the price of
V6.
Back to the point, the sound improvement over
HD515 was clearly there, but
HD598 were still surpassed by others - for me the sound of
HD598 seemed closer to
HD515 than to
K 701 or
DT 880/ 600.
Which brings us back to the fact that the phones I prefer are lean sounding, - so
it is personal preference.
That is why I ordered
HD600, not
HD650, as reviews point at
HD600 as the leanest of 580/ 600/ 650 series, and my hopes remain high.
