ev13wt
- Jan 24, 2007
Can you proove that or is it just something you think? I doubt Sennheiser would build a 200 dollar headphone and put in sub standard cables.
Well good to hear that pros don't need sound quality. I stand by my statement: The steel cable doesn't sound any different than any other cable.
As soon as I can get my hands on the replacement parts I will anodize the cups and joints a nice flat black.
I also like the fact that the headband now doesn't say Sennheiser on both parts of the split. That always was something I didn't understand, Senn could even have saved some cents if they only label one of the headband parts.
I did this to my Amperior and it looks fantastic. I'm not a fan of either of the colors that the Amperior came in....
Got no portable headphone I like atm so this looks very interesting, only bad thing is that aluminium looks really bad if it gets scratches. Worked alot with alu/and glass, usually the best is deep painted alu so scratches dont go trough. Still it looks nice in alu same as the silver Amperior. How good are this while you are running? I guess good since they have much clamp force.
Rosmadi:
The primary sound difference between the Amperior and the HD-25 25th Anniversary Edition (hereinafter defined as "25AE") seems to be the driver.
Other than the Amperior's being easy to drive (and woefully loud -- on my iPod 5G, there's no such thing as headroom, since you can still hear music at the lowest setting), what are the other differences? Are there significant sound differences between the 25AE and the Amperior?
What's mildly amusing is this: the Amperior was said to be an improved-sounding version of the HD-25, but the 25AE is being marketed as returning to the same high-quality sound of the original HD 25-II ("70 ohm pro drivers"!) but with the benefit of the aluminum cups.
Which is it -- is the Amperior's driver better than the 25AE's or worse?
Stay updated on Sennheiser at their sponsor profile on Head-Fi.
