PinkyPowers
Reviewer: The Headphone List
Check all connections. Clean your ears. Pray the drivers haven't contracted the wasting sickness.
So I've had the HD600s forever and it has always been a favorite next to the Thunderpants but recently I decided to upgrade my setup to a Modi 2 Uber + Valhalla 2. Sound definitely has improved but unfortunately away from my tastes. Now the HD600s sound a tad too bright on some recordings and seems to lack a bit in the low end overall. So I'm wondering, would the HD650 fix those problems with my current setup? I'm also using Amperex Orange Globe tubes on the Valhalla 2 if that helps. Any feedback is appreciated!
With the right tubes you can bring a good amount of warmth out of the Val.
I thought the Amperex Orange Globes would do the trick, but it really didn't quite do it for me. Perhaps the Bugle Boys would work better.
Would the HD700s be a good jump over the 600s with my particular setup?
Speaking from 10+ years of experience with HD600 - yes. And I'm not saying it's their fault.
Nothing is technically wrong with HD600, except a slightly anemic bass. HD800 with its sibilance is technically flawed in comparison.
I think you can try another DAC or other tube amplifier. I don't ahve Valhalla but I read people say it's just like a SS amp. You need a real tube amplifier. I don't think 700 fits your set up.
For me HD600/X2 combination would be ideal, I think.
