Sennheiser HD 600 Impressions Thread
Jul 15, 2014 at 9:34 PM Post #8,026 of 23,486
I liked it. Very 1960s.
Jul 15, 2014 at 10:03 PM Post #8,027 of 23,486
LMAO - I was just listening to Beth Hart's "Live At Paradiso" album while I was reading allets comment.
It's the bit between tracks where she sits down in the crowd, and tells them basically to "relax, put your feet up, smoke a joint .....".
Perfect comment WRT above posts
Jul 16, 2014 at 12:06 AM Post #8,028 of 23,486
Beth Hart live, aahhh... I love her voice!
Jul 16, 2014 at 4:13 AM Post #8,030 of 23,486
I love that Beth concert and listen/watch it regularly. I was a bit disappointed with the recent BD with Joe Bonamassa, Live in Amsterdam. She got the hair done and colored, high heels & dress... of course some of the drive and energy still lives under all that, but certainly no Paradiso quality.
Jul 17, 2014 at 5:53 PM Post #8,031 of 23,486
Does anyone know where to buy the black, oval foam cloths that cover the the drivers? I was trying to clean them yesterday and accidentally tore both to the point where they're useless now, so I need some more. Just the cloths that go under the velour earpads to protect the driver.
Any astute folks in the know, please message me.
Jul 17, 2014 at 6:39 PM Post #8,032 of 23,486
Here's the official spare part listing for Sennheiser UK:
http://headphonespares.sennheiser.co.uk/hifi-tv-headphones/hd-600-avantgarde/foam-discs.html
Presumably you can ask Senn USA for the same part?
Jul 19, 2014 at 6:17 AM Post #8,034 of 23,486
Hi everyone!
I am getting hd600 on tuesday but since I only have e10 now i want to get better amp. My question is if I should get o2 and use e10 as a dac only or do the same thing except with e09k OR get JUST e17 without e9. .. Thanks for any help
Jul 19, 2014 at 6:27 AM Post #8,035 of 23,486
Hi everyone!
The HD 600 will sound just fine out of an e10 - mine does!  It'll most likely sound better with a better amp, but the e10 will work.
O2 / e10 combo will work very well too.
The e17 on it's own won't really offer you anything over the e10, aside from the option of using it with a portable device.
Jul 19, 2014 at 6:32 AM Post #8,036 of 23,486
  I'm referring to this, to be clear, and let's take another classic can for comparison. I edited my previous post as per correct frequency area.
You typically will want to throw either more current or voltage to grab the can by it's hairy drivers. HD600 prefers more current, thank you.
Higher impedance means lower current, no?
Jul 19, 2014 at 6:47 AM Post #8,037 of 23,486
Thanks for quick reply!
I did expect that e17 won't be recommended over e10 but I didn't expect that e10 is supposed to do just fine. I wasn't planning to get the amp on the same day as hd600 anyway so I will see how will they perform with e10 alone. But I would still like to know if anyone could recommend e9 over o2?
Thanks
Jul 19, 2014 at 6:51 AM Post #8,038 of 23,486
Don't forget to add the Schiit Magni or Vali to your shortlist
Jul 19, 2014 at 9:56 AM Post #8,040 of 23,486
Hi everyone!
With the HD600 the better the amp the better they will sound. So... keep the E10 and get an o2. E17 is a portable DAC/AMP but i can't see why you would need something portable to use with the HD600 :p
The HD600 will be fine with the E10, so take your time to listen from the e10 and burn the headphones, and if the volume is low or you are willing to pay for something better, then i guess the O2 is a good amp.
