palmfish
There are only two things to remember when driving a 911. Don't lift.
Mine is older.... air cooled / no traction control
![biggrin.gif](http://files.head-fi.org/images/smilies/biggrin.gif)
Mine is older.... air cooled / no traction control![]()
u can roll diff tubes into LF336 to get diff flavors...v versatile.
i am loving my older darkvoice336se
high or low impedence cans, this amp never fail to impress me![]()
Guys, before I decide to get Crack or not I want to ask few questions.
- What is the sound for HD600+ Crack? Warm, neutral, bright? I read in review that Crack is neutral and fast. After spending times with warm amp and thick sound amp, I love warm, and fast sound. I afraid that the highs will be ear piercing in neutral amp, or perhaps Crack get them in control?
- Should I get the speedball or not for HD600? How much sound improvement from basic kit to speeball?
Have you compare with crack before? I know Crack is the current fever and recommended but I wish getting Crack is as easy as getting LF. Having so much fun with tube rolling huh?
I currently have the HD600 + Crack + Speedball combination and i love it. It definitely has a warm tilt, although this may be more attributable to the HD600 than the Crack. The Speedball helps to tighten up the bass and gives an overall 'quicker' presentation.
It's hard to quantify how much better the Crack is in stock form vs. with the Speedball; I will say that with the Speedball, the sound becomes more immediate and engaging. I loved the Crack in stock form though, to my ears it was more laid-back. Speedball or stock, the treble was nicely rolled off and never 'piercing'.
I was going to say you could come over and try out my rig but I looked up your location and Malaysia is a bit far from Los Angeles![]()
never heard crack b4![]()
My csp2+ cant handle low impedence cans...which means half my arsenal cant be used.
So its a point i would keep in mind in looking for a tube amp.
There is vintage junk and modern junk and then there is modern gear that is a step ahead. I don't think I'm "small minded" thank you.
I don't hear many folks upset with IM or TIM distortion, which is the worst, rather most go on about levels of THD that are academic and below our ability to perceive. I don't see OEMs disclosing these figures either.
As far as wallets go, in this hobby there is no hope, the HD800 is staring at me and I'm started to get hypnotized.
- What DAC recommended with crack and HD600, price wise about $300 and below. The cheaper the better.
Currently my alternative is LF 336C due to:
- Warm sound. But the downside is this amp more relax compared to Crack and I listened to heavy metal etc too.
- Easier to obtained and less hassle.
I'm open to other solid state amp for HD600 too within the same prize. Currently my DAC is Aune T1, upgrade in consideration. All my consideration done without listening to the mention amp. So, forgive me for my silly question. I just want to avoid too much upgradetitis.
I have not heard of the Crack, but had the 336 before and now the 339. I think the 336 is absolutely great with the Sennheiser, and it has endless tube choices as it uses the 6sn7. I listen to a fair bit of progressive rock and I never felt the combo being slow (that said, I normally reach out for an Alessandro when I listen to those genres).
If you read Headfonia's reviews, the Crack was slightly more preferred than the 336 due to their personal preference if I recall, but the 336 is cheaper and it is built while the Crack is a DIY. The 339 on the other hand is their favourite![]()
