martinrajdl
- Nov 28, 2012
I found the Valhalla2 to be a little to lean w/ paired with the 600. The little dot mk.iii was warmer and had that classic tube sound. But the mk.iii wasn't the most resolving amp. I'm currently using a Glenn otl with the 600,650 & 800's. Depends on ones budget though. These phones really shine with big otl amps such as the Zana Deux, stratus, and Glenn otls. I'd suggest auditioning gear if possible.
Unfortunately enough, where I live, I can't audition much, especially when it comes to source gear and amps. That's why I am trying to get as many opinions as possible here. There are also not all that many options that don't require importing. Also I am a bit worried about getting the tubes for tube rolling.
That is pretty much why I am deciding between getting Asgard 2 or Valhalla 2. Anyway thanks for the input.
