MarcoGV
- Oct 27, 2008
I have been using the HD598 with the Audioquest DragonFly 1.0 for a little over a year, and I like that combination a lot.
Nice. How big/noticeable would you say the improvement over your onboard audio was? Also, I saw one review that said it clips at max volume; is that an actual issue or not really since it never needs to be at max volume?
Thanks!
The big difference for me was against the output of my NAD 3120 amplifier, which has a high impedance. The bass of the HD 598 sounded bloated with that amplifier. This is because the HD 598 itself has much larger impedance at low frequencies than at high frequencies. With the Dragonfly, the bass bloat disappeared.
The _Stereophile_ review (http://www.stereophile.com/content/audioquest-dragonfly-usb-da-converter) explains that a pre-production version clipped at higher volume, but the production version does not. Audioquest recommends setting the volume to max when using the Dragonfly as a DAC that inputs to a separate amplifier. (I sometimes do that with a small tube amplifier.)
