Bunch of questions coming, sorry been holding them back for a while.
I currently run a Magni 3+ with a Modi Multibit. Used to run an Eitr too but the USB chip went out in it for the second time and I didn't want to send it back for a repair to Schiit for a second time. Plus Ive always thought I would upgrade the stack eventually anyway. My main headphones are Senn HD6xxs.
I always come to the Asgard and the Jot. Can someone, if you can, sort of describe the difference between the two amps and is the Jot worth the extra 150 bucks. Especially when taking into consideration the HD6xxs.
Also would the Jot be worth it even if I had no desire to run balanced?
How are the DACs that come in it?
It would be nice to have a one box solution but also the MM is really good, but doesn't have Unison USB, so I need to run some sort of decrapifier, so another box if I kept the MM in the chain. Also that mean Ill either need to send the Eitr back a second time to get fixed and hope the USB doesn't go again, of which I little confidence in since this is the second time its went out, there's gotta be something else wrong with it we aren't finding. OR I need to find another USB solution.
I know about the MM2 but Ive also heard it sounds nothing like the original and Im afraid I wont like it, So I dont really want to spend the 300 bucks on it unless Im sure. Also....its 300 bucks. I could probably find an old Multibit BF1 for that or less...Also Schiit appears to be selling multibit cards separately from the as/jot but for some reason aren't selling asgards or jots with them installed.
I am not 100 percent against D/S and even have a slight curiosity of how good D/S implementation sounds.
How is the multibit card in the Jot? Id heard they weren't as good as the MM when they first came out but Im sure they have been revisions made to it.
So sorry I know lots to unpack, but again Ive been mulling this for a while waiting for updates to the line and I think this is the right time.
