The 2 versions have pretty similar performance to the originals, the biggest update to both was extra features. Modi 2 got the simple/expert switch to enable 24/192 and Magni 2 got a gain switch.
I am just very into the Schiit product with the very competitive price to performance ratio. I also like their appearance design of the stacks. Sometimes its just the aesthetics that makes me feel better and more satisfied. Well the sound quality is also very important and Schiit pulls it of perfectly.
I am seriously looking into the Gumby/Mj2 stack upgrade.
I've contacted Schiit about this and already got an email from Nick T. but thought I'd throw this out to the collective wisdom.
I'm using my Uberfrost into an older Krell integrated amp (KAV-300IL). The source into the Uberfrost is a preamp with digital out so digitally volume controlled. Because the source is volume-controlled the Uberfrost uses a full-volume HT bypass input to the Krell.
Wit this setup I am getting hum. If I disconnect the coax source to the Uberfrost I still get the hum. Nick suggested I test with a cheater plug so I used a cord with the ground plug ripped off. Still with the hum.
Can anyone offer any other suggestions? After I tried with no ground I told Nick that I think the unit needs to be serviced.
Definitely a ground loop of some kind. Switch to optical if you can. I've used optical for years just because it breaks up electrical connections between devices.
