h2rulz
- Nov 7, 2015
Stop me if I'm crazy..
Is stacking the Valhalla 2 on top of an Asgard 2 a bad idea?
Both use their chassis as a heatsink, and both are class A. You're probably fine as long as you A) only use one amp at a time, or B) make sure to use feet to create some separation between each chassis.Stop me if I'm crazy..
Thanks for the inputs!
Good to know I wasn't too crazy![]()
Would the feets schiit provides create enough space, or would you recommend using something else with more height?
Say 3/8" or 1/2"?
Make of it what you will but I stack a Lyr 2 on top of the Bifrost using the supplied feet and have had no issues and that lyr gets pretty toasty.
I would not stack anything on my Asgard 2. No way. Too warm. But that's just me...
DAC on bottom, amp on top. All good
