Spiral Out
- Dec 31, 2013
Also try checking your DPC latency:
http://www.thesycon.de/deu/latency_check.shtml
I'm having a sound problem since I got Schiit Magni&Modi (a week ago).
Every now and then, the sound disappears for few seconds, usually when loading some apps (like Chrome, etc.).
It is most prominent while playing Battlefield 4, during one game it disappears at least 5-6 times randomly.
Anyone had this problem before? Could the problem be caused by a cheap USB cable (2m length) ?
Will try some of that, starting with cable, thanks.
The computer is powerful enough and I'm running Win7 64bit.
DCP latency 60 µs average, 71 max.
I don't think there are better drivers for Modi than ones supplied with Win ?
You still don't mention what sort of system.
Here's an idea: decrease the graphics quality on the game, and see if the problem goes away. Cutting down on the processing required to render high quality graphics will free up some CPU to process your audio.
CPU: Intel i7 2600K @ 4.4 / EK Waterblocks mod |
MBO: ASRock P67 Extreme6 |
RAM: 2 x 4gb DDR3 G.skill Sniper Series CL9 @ 1866mhz |
HDD: Samsung 470 Series 128gb |
VGA: nVidia GTX580 / EK Waterblocks mod |
PSU: Corsair HX850 |
OS: Win7 Ultimate X64 |
Much earlier my advice was to jiggle the cable, switch cables, check performance with task manager and then drivers. I left details, don't know if it was tried,
I highly doubt it's the system's fault. I never had sound problems before, even while benchmarking the system (extremely CPU, GPU and RAM hungry app - IntelBurnTest).
I'll try tonight to switch the cable.
PSU: Corsair HX850
Holy Cow.LOL. Passmark 8600 for the CPU and 4900+ for the GPU.![]()
That's a lovely motherboard, by the way.
Ok, that system should not be choking up on the game. ROFL. Now I'm laughing at myself for doubting your computer. Hah.
So, yeah. Let's go back to the cables.![]()
And drivers.
"Ultimate" cannot be an issue, it's the same platform, just with some features unlocked![]()
Regarding drivers, I don't know if they may cause problems, but I have 2 drivers installed currently, Modi's and my old Realtek's, which I use to listen to my mini-Hifi connected to my computer's soundcard. If cables don't work then I guess I should just format it and reinstall everything from scratch.
