Schiit Owners Unite
- Thread starter hodgjy
William007
- Jun 3, 2012
paradoxper
They got rid of some noise, for whatever that's worth.
what do you think of the PYST?
Rope
- Feb 28, 2011
Short PYST, won't reach my Schiit!!
gmahler2u
- Dec 19, 2011
I order the toslink and I got the cable. When I tried to put the cable into my macbook. It doesn't have anywhere put the cable.
help!
Thanks
There isn't a clear cut answer to this. Everyone's system is different, and toslink has its pro's and con's as does USB.
If you're on PC I prefer coaxial. Mac toslink.
help!
Thanks
Radioking59
- Aug 6, 2010
It's hidden in the headphone jack. You need an adapter like this:
http://www.amazon.com/Recoton-Fiber-Optic-Toslink-Adapter/dp/B0002MQGRM/ref=pd_cp_e_0
I'm not necessarily recommending that one. It was the first one I found.
help!
Thanks
Rhyno46
- Aug 7, 2012
Received my bifrost and Asgard today, to match my senn hd650.
I have one disappointment... I didn't bring the stack home with me tonight. This is my office setup and all I want to do is listen right now.
I also have some anxiety... Should I have popped for the Valhalla instead?
paradoxper
Nope. Though Lyr would have been preferred.
Or exchange the cable you received for a mini-toslink to toslink, better than an adapter. Amazon doesn't carry them but if you want a glass cable like that they start at around $50. Amazon does have standard glass toslink for less than half of that though.
Quote:I order the toslink and I got the cable. When I tried to put the cable into my macbook. It doesn't have anywhere put the cable.
help!
Thanks
Rhyno46
- Aug 7, 2012
Softball-->"send that Schiit back for a better Schiit"
Nylerb
- Aug 12, 2012
Hi !
Just received my Schiit Lyr. I never had any "tubes" amp before, so I got a silly question :
How bright the tubes has to be ? I expected they would light up almost like a.. lamp, or something, but in fact there are only 2 orange dots in each of the tube.
I wonder if this is normal ?^^
paradoxper
Yep, it's perfectly normal. Voltage heaters differ from amp to amp.
Hi !
Nylerb
- Aug 12, 2012
Oh okay, thanks !
Just by curiosity : what happens when the tubes broke ? You can't hear the music anymore ? Or can you still drive the headphones but the sound quality is decreased ?
paradoxper
No problem.
What do you mean by broke? If they're literally shattered you couldn't possibly roll them in Lyr.
Often times a clear sign of a tube dying will be various noises, hissing, crackling, and other non describable sounds.
And no, you can't have Lyr drive headphones with no tubes in it.
Most likely you'll hear it i(or not hear) on one channel, I've never had tubes simultaneously go out on me. So if no music in left or right ear
the tubes quit on ya. Or one of your headphone drivers failed.
Oh okay, thanks !
No problem.
Nylerb
- Aug 12, 2012
Ok thanks Now I know !
Total: 8 (members: 0, guests: 8)
