Schiit Lyr Tube Rollers
Apr 17, 2019 at 12:09 AM Post #20,671 of 23,494
That are the codes on the metal plate? They look like Siemens to me. Have you looked for a faint CCa on the first tube? The codes on the plate will tell you they are Siemens. But thwhag e CCa and E88CC will have the same codes from what I remember.
Apr 17, 2019 at 12:25 AM Post #20,672 of 23,494
you mean this code ?
Apr 17, 2019 at 12:38 AM Post #20,673 of 23,494
My gut feeling says pass, no proof the left tube with no paint is a CCa and the 2 CCa have different change codes and possibly different years. Euroclag on eBay sells the Ao revision with grey shield on eBay. Tube A0 is considered the best by many. You can ask in the thread here if a anybody wants to sell a pair.p
Apr 17, 2019 at 1:08 AM Post #20,675 of 23,494
Apr 17, 2019 at 1:22 AM Post #20,676 of 23,494
Any thoughts on Telefunken ECC82/12AU7 smooth plate tubes? I don't own any TF's and am curious if these are worth a shot at less than $100 for a pair.
Thx!!
Defiantly a fuller sound than other Teles I've listened to. Can be slightly bright on the top end depending on listening setup. One of my favorites for instrumentals and rock. Quite revealing and a keeper in my book.
Apr 17, 2019 at 3:39 AM Post #20,677 of 23,494
I have a pair of Siemens CCa that I could let go for 200$ made in 1965 test over 100% on Gm on my tester and 90-100% Ia (13mA). Haven't shipped to Indonesia though so not sure how that goes. I think it's a fair price considering most matched pairs on ebay go for 300$+ nowadays. But if you want to hunt I feel like you can score a better price if you buy singles and have a tester (always risk involved though :p).
Apr 17, 2019 at 4:34 AM Post #20,678 of 23,494
Apr 17, 2019 at 4:35 AM Post #20,679 of 23,494
I don't know much about the ECC82 but these are Siemens tubes you can see the etched codes on the side.
Apr 17, 2019 at 6:03 AM Post #20,681 of 23,494
Thanks kolkoo! I am not sure what is going on with these! Just looking around on eBay and found them
What are the prices on ebay for ECC802S generally?
Apr 17, 2019 at 6:17 AM Post #20,684 of 23,494
I was looking closer at the tubes that are supposedly real Tele ECC802S and the internal construction is different from the listing I posted, so not sure what the one I posed is.
If you're going to pay that much you can buy from http://www.nostubestore.com/search/label/ECC82/12AU7 - EUROPEAN BRANDS , I've bought 5-10 pairs of various tubes from the throughout the year, they ship from Turkey but their tubes are amplitrex tested which is basically the best.
Edit: my Dam Son reaction was meant towards the price of 750-850$ :D
Apr 17, 2019 at 6:53 AM Post #20,685 of 23,494
