Schiit Lyr Tube Rollers
Apr 17, 2019 at 5:51 PM Post #20,701 of 23,494
I'm thinking the owner of pair19 isn't gonna like them anyway, so maybe I will wind up with them after all. :wink:
lol, Don`t think I ever owned any Telefunken with a 4 seam top bro. do you have a real small tool to go over the diamond to see if it is a positive, legit? if its laser`d you will feel the tool or whatever dropping in the diamond. Asking a lot as its a real small surface.
Just had a portable hard drive die on me, I blame the Indian Tele`s I`m burning in.
Apr 17, 2019 at 5:52 PM Post #20,702 of 23,494
Well, I guess I have seen it all now. My ECC801s (My third pair) arrive today from India. At least both have bottom diamonds but 1 tube is marked 12AT7WA. Yes, I guess it technically is a 12AT7WA, but I have NEVER EVER seen any marked that way. It gets worse...both tubes have 4 top seams, on top of the tube, like a Siemens or Amperex. My other 2 pairs of 801S have no seams. What???
I had a pair that were marked 12AT7WA for export markets. They were genuine 801s.
Is the third mica transparent or opaque?
Apr 17, 2019 at 5:55 PM Post #20,703 of 23,494
Apr 17, 2019 at 6:01 PM Post #20,704 of 23,494
Structurally it all looks legit. Third mica is translucent...you can see thru it. Also, they have the double getter supports. Short getter flashing and thin "O" getter.
AC, everything checks out. Diamond feels "positive/raised" but hard to tell with an unfolded paperclip.
Apr 17, 2019 at 6:05 PM Post #20,705 of 23,494
Some older ones have an opaque mica, and have fat getters (there's another getter attached to the angled post on those ones).
Kolkoo posted the various types a while back, there's quite a few variants, but I still have never seen another tube with the same construction as the 801s, so I don't think there's anything to panic about.
Same can't be said for the 802s, and 803s unfortunately.
Apr 17, 2019 at 6:11 PM Post #20,706 of 23,494
@AuditoryCanvas
What do you think of these cables?
1.Pangea Audio AC 14SE MKII Signature Power Cable (1.5 Meter) https://www.amazon.com/dp/B00V75CYL0/ref=cm_sw_r_cp_tai_ZhATCb3V78F8X
2.Stratus 7 power conditioning cords https://store.wireworldcable.com/products/copy-of-stratus-7-power-conditioning-cord
Or would you recommend the ones you listed over these?
“heavyweight chords for power from the power conditioners” (https://www.amazon.com/dp/B01L2SBWK...&pd_rd_r=c6c75fd5-5ff2-11e9-9672-417ebf68296c)
Thank you!
Apr 17, 2019 at 6:14 PM Post #20,707 of 23,494
@AuditoryCanvas
Thank you!
Just got last link ones today, to say they are not thin is a gross understatement.
Apr 17, 2019 at 6:18 PM Post #20,709 of 23,494
@AuditoryCanvas
Thank you!
Pangea are good cables, I just got the ones I linked to for the weight and price. Either will be a better result compared to a stock cable, I doubt you'd be able to tell the difference between the two in terms of sound tbh.
